Hi All,
After a break from this, I'm back and still having probs.
Done a fresh install, and cant get around the broken image issue and a lib error as shown
Other than that, cam is green etc, so it seems to be working,,
[root@amd64 tmp]# more /var/log/zm/zmdc.log
Server starting at 05/03/26 23:18:18
'zmc -d 0' started at 05/03/26 23:18:21
/usr/lib/zm/bin/zmc: error while loading shared libraries: libpcre.so.0: cannot open shared object file: No such file or directory
Can't find child with pid of '12993'
'zmc -d 0' starting at 05/03/26 23:18:21, pid = 12993
'zma -m 1' started at 05/03/26 23:18:21
/usr/lib/zm/bin/zma: error while loading shared libraries: libpcre.so.0: cannot open shared object file: No such file or directory
Can't find child with pid of '12996'
'zma -m 1' starting at 05/03/26 23:18:21, pid = 12996
'zmfilter.pl' started at 05/03/26 23:18:21
'zmfilter.pl' starting at 05/03/26 23:18:21, pid = 12999
'zmaudit.pl -d 900 -y' started at 05/03/26 23:18:22
'zmaudit.pl -d 900 -y' starting at 05/03/26 23:18:22, pid = 13003
'zmwatch.pl' started at 05/03/26 23:18:22
'zmwatch.pl' starting at 05/03/26 23:18:22, pid = 13008
'zmupdate.pl -c' started at 05/03/26 23:18:22
'zmupdate.pl -c' starting at 05/03/26 23:18:22, pid = 13012
Although the requested file is present as shown
[root@amd64 tmp]# find / -name libpcre.so.0
/lib64/libpcre.so.0
/usr/local/lib/libpcre.so.0
Any ideas, its already driving me nutts and i so want to get this working as it looks great!
Here is my ld.so.conf incase you need it
[root@amd64 tmp]# more /etc/ld.so.conf
include ld.so.conf.d/*.conf
/usr/X11R6/lib
/usr/X11R6/lib64
/usr/local/lib
/usr/lib64/mysql
/usr/lib
/usr/lib64
Libpcre.so.0 probs and broken image
- zoneminder
- Site Admin
- Contact:
solved the libpcre.so.0 problem
Do u have pcre-devel installed on ur system.If yes then just copy pcre.h from /usr/include/pcre/pcre.h to /usr/include/pcre.h.
I was having the same prob ,Doing this i solved my problem.
Best of luck
________
ipad guides
Best of luck
________
ipad guides
