Logical AND of two Modect
Posted: Tue Mar 29, 2005 1:45 am
Can ZM do a logical AND of two Modect cams?
Logical AND means that only if the two (or more) cams detect motion an event is triggered.
What would that be good for, you ask?
With two cameras aimed at the same object under an angle of 90 degrees ZM could generate a "3D event volume" around that object.
Wouldn´t that be a nice feature?
Best Regards
Juergen
Best Regards
Juergen
