Page 1 of 1
is there a way to start and stop on commandline for zm ?
Posted: Wed Mar 30, 2005 7:19 pm
by aot2002
Posted: Wed Mar 30, 2005 8:12 pm
by Eklectick
Hi
I have a LiveCD installation, I do not know if installing it another way triggers ZM differently, I belive it could, but via command line on LiveCD, I can stop it by typing "service zm stop" and start it by typing "service zm start".
Regards!
Posted: Wed Mar 30, 2005 8:16 pm
by cordel
Service zm start
and
service zm stop
or
service zm restart
All should work (They do on my CD anyway)
If you compiled the souce then you have to manualy install the zm script to init.d as detailed in the readme.
Cheers,
Cordel
Posted: Thu Mar 31, 2005 8:39 pm
by aot2002
i should of been more specific ....what i mean is if i reboot then i need to go into the console to start zm....
using the commands you gave me doesnt do it.
anything else?
Posted: Fri Apr 01, 2005 7:08 pm
by zoneminder
In Fedora and the like you can use chkconfig to set ZM to start up automatically. I'm sure there is an equivalent in other distros as well.
Phil
Posted: Wed Apr 20, 2005 1:53 pm
by aot2002
it works but i had to reinstall FEDORA stratched CD !
