Ho to start X?
Support and queries relating to third party Live CDs and DVD, VM images and other packaged distributions
kele76
Ho to start X?
Post by kele76 »
After start from cdlive and login as root how can i launch X?
rdmelin
Post by rdmelin »
You should not have to. It should start automatically. If it doesn't the most common reason is not enough RAM. You need 256MB.
Another possible reason is a corrupt CD either from a bad download or a bad burn. You can use MD5SUM to check both the ISO file you downloaded and the CD.
Still another possible reason is that the CD failed to properly detect your display card. You could try some of the bootcode switches to see if they make any difference.
Best regards,
Ross
kele76
Post by kele76 »
I have athlon 1,2Ghz 256 Mb ram
Detected card is right:Matroz g400 Dualhead 32Mram
i try to reburn cd.
I have only an error on pst :what is?
[Mandrake 10 work fine on my pc if when i installed it]
