Keeping disk usage to a minimum
I've got ZM running on a server with 200G partition for the data. It has filled up very quickly because of the necessity to record for most of the day. Even though we go through and manually delete events, it seems that the auditor isn't working that well, even though there is no errors in the logs. What I'm after is to be able to get ZM to ffmpeg every event at the end of the day and have it in an archive for review. Is this possible? I'd be interested to hear from other users...
Hello.
I'm working on a script, which will be run via the ZM filters system, and will compress the JPG's to MPG, removing the JPG's. The problem is, that I need to modify ZM to support these MPG's, meaning, it will recognize that the video was converted and playback it accordingly. It's under works, but will be eventually completed.
When it done, I will submit this script to the contrib. forum.
- zoneminder
- Site Admin
- Contact:
- zoneminder
- Site Admin
- Contact:
