No recording?
Posted: Thu Apr 21, 2005 1:38 pm
I've got ZM 1.21 up and running and looking at a Dynamode network camera.
I've defined the monitor to pull jpeg files off the camera and set the mode to "record" with a section length of 10 seconds.
Looking at the "watch" window I can get static images, and I've turned the rate up to one per second to make it usable, but there are two problems
1) if I switch to "stream" then I get a blank screen. The status in either stream or still pictures is "Idle - 0.00 fps". The camera supports streaming from a dedicated port, but I gather the functionality isn't yet there to connect to the stream port on the camera.
2) Although the monitor's source and function fields are green, I am getting nothing recorded. As I understand it, I should be getting continuous 10 second segments and, I assume, the event counter incrementing every 10 seconds. Nothing's being written to the "images" directory (although the directory for the monitor itself has been created in there) and no events are being registered. Nothing's going into the event log that looks relevant- although I've had to turn all the buffer sizes down to 1 frame and keep getting "buffer overrun" errors. Surely it can work with 1 frame buffers?
The second thing seems like it should be a trivial setup problem- as if I have to arm something to enable recording, but I can't see anything. Can anyone help?
