I've been trying to get an saa7146 sixteen channel DVR board to worl with ZoneMinder. There is a video4linux driver for it and it shows up under /dev as:
individual devices: vcs, vcs1 through vcs7 and vcsa0 through vcsa7.
and in the /dev/vcc directory as: 0 through 7 and a0 through a7.
Is there any Linux trick I can use to get this device to show up under /dev/video? The uncompressed video output of the board should be compatible with those handled by ZoneMinder. This is a basic board w/o any hardware compression.
I'm using the ZoneMinder Live cd upgraded to ver 1.21.0
Any help or comments would be appreciated. Even knowing it can't be done would be a big help.
I have an SAA7146 based board sort of working in ubuntu 5.10.
I say sort of because i cannot get streaming to work in mpeg mode, only in jpeg mode.
I am new to zoneminder and getting video working in linux too. So it could just be that.
Anyway, i have got a camera connected up to the board in motion detection mode, and it seems to work ok, capturing a bunch of still frames when anything moves.
I was trying out ubuntu on the machine which just happened to have the card in the PCI slot and the little red LED lit up, so i figured i'd stick with ubuntu for the CCTV machine i am building.
If there is anything i can look at on my machine to help you guys out, let me know. You might have to take me step-by-step through it though. I am familiar with linux, but by no means an expert.
Hello.
I have the same problem. My card is HICAP 50B and my linux fouund the prorpyate driver for it saa7146, but i have no respond from vcs->vcs8.
When i try to run v4l-info the result is :
"open /dev/video0: No such file or directory".
