Page 1 of 1
ffmpeg mpeg generation problem
Posted: Thu Apr 28, 2005 10:26 am
by felixchu
hi, I have installed ffmpeg 0.4.9-pre1 but there is a probblem when I generate mpeg from the motion detected jpeg files.
Error Message:
Duration: 00:00:07.3, bitrate: N/A
Stream #0.0: Video: rawvideo, yuvj420p, 320x240, 8.21 fps
Output #0, mpeg, to 'Event-195.mpg':
Stream #0.0: Video: mpeg1video, 320x240, 10.00 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
[mpeg1video @ 0x8266698]MPEG1/2 doesnt support 10/1 fps
Error while opening codec for stream #0.0 - maybe incorrect parameters such as bit_rate, rate, width or height
Error: 1 at /usr/local/zm/bin/zmvideo.pl line 274.
I find that zm runs following command with erro:
/usr/local/bin/ffmpeg -y -r 8.21 -s 320x240 -i %03d-capture.jpg Event-195.mpg > mpeg.log
I tried to remove "-r 8.21", then it can generate the mpeg successfully. But the frame rates seem nor normal, it runs very fast. Therefore, I cannot remove this "-r" parameter in ZM.
Any one can advise how to solve it? Thanks.
Posted: Fri Apr 29, 2005 8:09 am
by felixchu
I have solved.
Thanks a lot.
Posted: Mon May 02, 2005 5:25 pm
by cordel
Could you please postt your solution?
Regards,
Cordel
Posted: Thu Jul 07, 2005 9:43 am
by mikkox
I would need also solution for the specific problem. Could you post it?
-Mikkox
Posted: Thu Jul 07, 2005 6:15 pm
by tommy
I had same problem.
Fixed by adding -strict -1 to ffmpeg generation parameters as reported elsewhere in the forum.
Posted: Fri Jul 08, 2005 9:39 am
by mikkox
Thanks... :D
Now it works perfectly.
-Mikkox
