but the images web adress is : http://192.168.0.3/var/www/html/zm/even ... apture.jpg
whereas the gui web adress is http://192.168.0.3/html/zm/index.php
So I removed /var/www/ from ZM_DIR_EVENTS. but then no frames are recorded
logs are clean except some perl scripts which die with signal 14
I dont know where to look to fix that annoying point.
[edit]
Add of my configuration
zm version v1.21.0 compiled on ubuntu, with bt848A chip, apache2, php 4.3.10, mysql 12.22.
The server adress is 192.168.0.3 and I use firefox 1.0.3 on a windows 2000 machine.
tnx for help and advices.
Jolaf'
