Confused with paths
Posted: Mon May 02, 2005 11:12 pm
The problem is that if I set ZM_DIR_EVENTS to : /var/www/html/zm/events jgp files are fine stored in a directory which is /var/www/html/zm/events/1/7/ (camera 1, event 7)
but the images web adress is : http://192.168.0.3/var/www/html/zm/even ... apture.jpg
whereas the gui web adress is http://192.168.0.3/html/zm/index.php
So I removed /var/www/ from ZM_DIR_EVENTS. but then no frames are recorded
and disk occupancy (gui upper right corner) indicates -1%.
logs are clean except some perl scripts which die with signal 14
I dont know where to look to fix that annoying point.
[edit]
Add of my configuration
zm version v1.21.0 compiled on ubuntu, with bt848A chip, apache2, php 4.3.10, mysql 12.22.
The server adress is 192.168.0.3 and I use firefox 1.0.3 on a windows 2000 machine.
tnx for help and advices.
Jolaf'
[edit]
Jolaf'
