definitions for image storage vs image stream
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
djsb
Post by djsb »
In some cases it would be great to store an high quality image but view it over a dsl link that cannot handle the images size.
If there would be an option to set this we could have the following:
store at: 640x480, rgb24
view at: 320x240, gray scale
if we really need to see it with more definition we could always change the viewing options.
cordel
Post by cordel »
You wil find that in the options under high, medium, low B/W you can set the scale, bit rate ect...
and under the Config tab you can set the stream quality vs the saved image quality.
Is this what you are loking for?
Regards,
cordel
djsb
Post by djsb »
it's that! But i don't understand if the scale of the image is done on the server side or on the browser... If it is on the browser it consumes the link...
cordel
Post by cordel »
All those features control what happens on the server side.
djsb
Post by djsb »
but image color depth can't be changed for streaming...
