Page 1 of 1
definitions for image storage vs image stream
Posted: Tue May 17, 2005 2:55 pm
by djsb
In some cases it would be great to store an high quality image but view it over a dsl link that cannot handle the images size.
If there would be an option to set this we could have the following:
store at: 640x480, rgb24
view at: 320x240, gray scale
if we really need to see it with more definition we could always change the viewing options.
Posted: Tue May 17, 2005 9:56 pm
by cordel
You wil find that in the options under high, medium, low B/W you can set the scale, bit rate ect...
and under the Config tab you can set the stream quality vs the saved image quality.
Is this what you are loking for?
Regards,
cordel
Posted: Wed May 18, 2005 8:29 pm
by djsb
it's that! But i don't understand if the scale of the image is done on the server side or on the browser... If it is on the browser it consumes the link...
Posted: Wed May 18, 2005 10:53 pm
by cordel
All those features control what happens on the server side.
Posted: Fri May 20, 2005 12:01 pm
by djsb
but image color depth can't be changed for streaming...
