Frame order problem
alex2b
Frame order problem
Post by alex2b »
I'm using 1.20.1, on fedora core 2, SMP system with 2 P-III 350
I have 1 camera connected via tv-tunuer board with bttv chip.
Frame params are 576x432, grey, max fps 25. I use modect mode.
When event is saved, frames are mixed.
For example, first go frames for time: 14:02:49-14:02:50, then 14:02:52-14:02:53, and then I have frame from 14:02:51 to the end of event with exclusion of 14:02:52-14:02:53.
What should I try to fix this?
zoneminder
Site Admin
Post by zoneminder »
I'm not sure I exactly understand what you are saying is wrong. Can you paste the frames tables from the web pages into here so I can see the timings.
Phil
alex2b
Post by alex2b »
Not sure what to paste to make it clear. Let me explain again.
Frame numbers are correct. But somewhere in the middle of frame sequence happens following:
frame 20: Catpured at 12:13:00
frame 21: Catpured at 12:13:02
frame 22: Catpured at 12:13:01
This is just an example, not real sequence. Do you get the problem?
alex2b
Post by alex2b »
I've got more info
I had ring buffer set to 50 frames and pre-event buffer to 30. May this cause the problem?
And more details about problem:
First i had 30 files from 001-capture.jpg to 030-capture.jpg, than 031-analyse.jpg and so on
And frames 001-capture.jpg to 030-capture.jpg were captured LATER than (031-analyse.jpg and on). But save BEFOR them
Now I've set buffer sizes to recommended values, will see if it helps.
alex2b
Post by alex2b »
Ok, now everything works fine :D
There was problem with wrong buffer settings.
Sorry.
zoneminder
Site Admin
I'm glad you got it working, though I still don't really understand why the problem occurred beforehand :?
Phil
