capture images and compress them.....
angelhod
Post by angelhod »
hi
is there any way to make captured images compressed or something?
because now when i set maximum fps to 10 one minute takes about
9MB from the disk space...
sorry if this question is stupid but i am really short of disk space on my home server so i need to solve this problem somehow....
thank You for any help
zoneminder
Site Admin
Post by zoneminder »
Captured images are jpeg files so they are compressed. You can increase the compression factor (and this reduce the quality) by going to Options->Config and changing ZM_JPEG_FILE_QUALITY to a lower value. You can also use 'Frame Skip' in the monitor settings to only save one frame in every n.
Phil
