Page 1 of 1
Make custom liveCD error:help Me :)
Posted: Sat May 28, 2005 4:35 pm
by kele76
I install liveCD 1.21,than install kernel 2.6.11 as described in post about philips vesta webcam on this forum.
then after edit mkzmcd file i have this error:
Creating initrd: [ 59.72% 00:00:03/00:00:05]DIE gzip -dc /lib/modules/2.6.11-9mdk/kernel/fs/isofs/isofs.ko.gz >/home/use ...
FATAL: unable to find kernel module 'cdrom'
what i do?
thanks Michele.
Posted: Tue May 31, 2005 11:55 pm
by rdmelin
I believe the 2.6.11 Mandrake kernel has cdrom support compiled in rather than using a module. So there is some incompatability with the version of mklivecd that is on the livecd.
I will compile updated rpms for mklivecd and livecd utils and post a link when I get a little time. But you should be aware that you will find other issues when running the 2.6.11 kernel on Mandrake 10.1. At least one that I am aware of is that CD burning will break. Fixing it will require rebuilding cdrecord at least.
A simpler solution may be to build the camera driver you need for the tmb kernel used on the livecd. I'll take a look at this option too when I get a few minutes.
Best regards,
Ross
Posted: Wed Jun 01, 2005 1:28 am
by rdmelin
Is it the philips webcam driver that you need? If so the se401 module is included on the livecd. The camera may not be auto detected, but doing "sudo insmod se401" may be all you need to do to get it going.
Ross
Posted: Fri Jun 03, 2005 1:03 pm
by kele76
thanks for attention on my proble.
Yes my camera is philips vesta pro 640K
and work only at 160X120 and not at 640*480 as in windows.
after in insert module can i remake cdlive and bourne it?
another problem:i have as video card matroxg400 dual head with tv (pal) out.
How can use it:i must recombile kernel?
If i must recompile where i find kernel configuration file?
thanks.mike
Posted: Mon Jun 06, 2005 1:24 am
by rdmelin
OK the "philips vesta pro" is supported by the pwc module. Another user pointed out that the pwc module on the livecd is somewhat crippled.
I have compiled a new driver for the Philips webcam with the extension module to get full resolution. I don't have one of these cameras so it has not been tested. But I expect it will work as advertized.
You can get it here:
http://www.elltel.net/melins/mdk_10.1/D ... c_mods.tgz
Just inzip it and follow the instructions in the README.
If you want the modules to always load at bootup add them to /etc/modprobe.preload
Then you can remake the livecd and you will have full support for your camera.
I will look onto the matrox TV out thing when I get some time.
Best regards,
Ross
