Gentoo Linux, kernel 2.6.11.11. Apache 1.3.33. PHP 4.3.10. MySQL 4.0.24. ZoneMinder 1.21.0. Everything but MySQL is compiled by hand (portage just ISN'T right for some things..). Freshly new compiled version of ZoneMinder (as of writing this, brand new install).
(writen some hours later..)
I was finally able to solve one problem by installing many, many *grumble* perl modules, but now I seem to have another and I'm so fustrated now that I'm really hoping someone can help me. ZM appears to start, and load all of the perl scripts it needs. If I open the browser, it reports as running. But the video source, no matter what channel I try, remains red. Within just a minute or so, if I look at ps aux, I get only a single process running.
/usr/bin/perl -wT /usr/local/bin/zmdc.pl stop zma -m 1
zmaudit.log
Found database monitor '1', got 0 events
Server starting at 05/06/06 00:43:55
'zmc -d 0' started at 05/06/06 00:44:00
'zmc -d 0' starting at 05/06/06 00:44:00, pid = 7604
'zmc -d 0' crashed at 05/06/06 00:44:00, exit status 255
'zmc -d 0' starting at 05/06/06 00:44:00, pid = 7606
Can't select: Is a directory at /usr/local/bin/zmdc.pl line 593.
Server starting at 05/06/06 00:44:02
'zmfilter.pl' started at 05/06/06 00:44:05
'zmfilter.pl' starting at 05/06/06 00:44:05, pid = 7632
'zmaudit.pl -d 900 -y' started at 05/06/06 00:44:13
'zmaudit.pl -d 900 -y' starting at 05/06/06 00:44:13, pid = 7638
'zmwatch.pl' started at 05/06/06 00:44:16
'zmwatch.pl' starting at 05/06/06 00:44:16, pid = 7644
'zmupdate.pl -c' started at 05/06/06 00:44:20
'zmupdate.pl -c' starting at 05/06/06 00:44:20, pid = 7649
Can't find process with command of 'zmc -d 0'
'zmc -d 0' starting at 05/06/06 00:45:10, pid = 7684
'zmc -d 0' started at 05/06/06 00:45:10
'zmc -d 0' crashed at 05/06/06 00:45:11, exit status 255
'zmc -d 0' starting at 05/06/06 00:45:11, pid = 7686
'zmc -d 0' started at 05/06/06 00:45:11
Server starting at 05/06/06 00:45:13
Can't find process with command of 'zma -m 1'
Scanning for events
Command: start
Executing: su nobody -c '/usr/local/bin/zmdc.pl check'
Removing shared memory
Executing: su nobody -c '/usr/local/bin/zmfix'
Executing: su nobody -c '/usr/local/bin/zmdc.pl status'
Executing: su nobody -c '/usr/local/bin/zmdc.pl start zmc -d 0'
Executing: su nobody -c '/usr/local/bin/zmdc.pl start zmfilter.pl'
Executing: su nobody -c '/usr/local/bin/zmdc.pl start zmaudit.pl -d 900 -y'
Executing: su nobody -c '/usr/local/bin/zmdc.pl start zmwatch.pl'
Executing: su nobody -c '/usr/local/bin/zmdc.pl start zmupdate.pl -c'
Update agent starting at 05/06/06 00:44:22
Watchdog starting at 05/06/06 00:44:18
Watchdog pausing for 30 seconds
Can't get shared memory id '2053971969': No such file or directory
EDIT: I just tried to restart ZM. And when trying to view the stream, I get a broken image. But trying to force 'view image' with firefox, I get a 500 internal server error. In my apache error_log, apparently the cgi is broken, I have..
[Mon Jun 6 01:08:59 2005] [error] [client 192.168.1.102] Premature end of script headers: /usr/local/apache/cgi-bin/zms
