I've got Zoneminder working very nicely, with one exception.
When I have authentication disabled, everything works perfectly. However, as soon as it's turned on, I can log in as any of the users I have created, but am unable to play events or view the camera outputs (these generate an HTTP 500 internal server error), both viewing the stills, or using Cambozola (even as admin). I have tried restarting apache, and ZM, but to no avail. As soon as auth is disabled, things go back to working.
The apache error log shows:
Error, unable to authenticate user
[Tue May 31 15:32:02 2005] [error] [client 192.168.44.132] Premature end of script headers: zms, referer: http://192.168.44.142/zm/index.php?view ... c=0&page=1
Can anybody offer any hints as to what might be wrong?
Thanks,
David
Problem when using authentication
Are there any errors showing in zmdc.log?
What distro are you using?
Apache Version?
PHP version?
ZM version?
Regards,
Cordel
Apache Version?
PHP version?
ZM version?
Regards,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
