wired internet connection and wireless console connection
Posted: Thu Jun 02, 2005 3:56 pm
I'm setting up a zoneminder box to go into a remote location. I want to access the ZM control panel via a wireless link from a laptop to the box. I also want the ability to plug the ZM box into my ethernet router at certain times to access the internet or other computers on my wired network.
My problem is that I can't get both connections to work at the same time. With some fiddling I can get one or the other to connect.
The wired side is set at 192.168.2.11 and goes to a linksys router.
The wireless side is an MSI PC54G2 card at 192.168.3.11 and connects to the laptop at 192.168.3.69.
I suspect that possibly the Mandrake Network Control center can't handle this situation. Does anyone have any clue on what I need to do?
Kirk
Kirk
