Page 1 of 1
hardware issue with 4 port card from EBAY 60fps
Posted: Thu Jun 09, 2005 2:52 am
by aot2002
im using this ebay card here
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... &rd=1#tech
its a 4 port 60 frames per second
i thought it was similar to bbtv type ebay cards the ones with 30fps but i cannot seem to get fedora core 3 to detect this card ?
i've tried a modprobe but still no luck ?
is there some way to get this type of card working ?
please help ?
here is my zmdc.log
Can't locate MIME/Entity.pm in @INC (@INC contains: /usr/lib/perl5/5.8.5/i386-linux-thread-multi /usr/lib/perl5/5.8.5 /usr/lib/perl5/site_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.4/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.3/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.2/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.1/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.0/i386-linux-thread-multi /usr/lib/perl5/site_perl/5.8.5 /usr/lib/perl5/site_perl/5.8.4 /usr/lib/perl5/site_perl/5.8.3 /usr/lib/perl5/site_perl/5.8.2 /usr/lib/perl5/site_perl/5.8.1 /usr/lib/perl5/site_perl/5.8.0 /usr/lib/perl5/site_perl /usr/lib/perl5/vendor_perl/5.8.5/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.4/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.3/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.2/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.1/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi /usr/lib/perl5/vendor_perl/5.8.5 /usr/lib/perl5/vendor_perl/5.8.4 /usr/lib/perl5/vendor_perl/5.8.3 /usr/lib/perl5/vendor_perl/5.8.2 /usr/lib/perl5/vendor_perl/5.8.1 /usr/lib/perl5/vendor_perl/5.8.0 /usr/lib/perl5/vendor_perl) at /usr/local/bin/zmfilter.pl line 102.
BEGIN failed--compilation aborted at /usr/local/bin/zmfilter.pl line 102.
'zmfilter.pl ' crashed at 05/06/08 19:44:34, exit status 2
here is my zmwatch.log
Can't get shared memory id '2053971969': No such file or directory
What seems to give here ?
here is my /var/log/messages
Jun 8 19:41:50 localhost zmfix[3007]: ERR [Can't stat /dev/video0: No such file or directory]
Jun 8 19:41:53 localhost zmc_d0[3034]: INF [Debug Level = 0, Debug Log = <none>]
Jun 8 19:41:53 localhost zmc_d0[3034]: ERR [Failed to open video device /dev/video0: No such file or directory]
Jun 8 19:41:53 localhost zmc_d0[3036]: INF [Debug Level = 0, Debug Log = <none>]
Jun 8 19:41:53 localhost zmc_d0[3036]: ERR [Failed to open video device /dev/video0: No such file or directory]
Posted: Fri Jun 10, 2005 2:47 pm
by zoneminder
Essentially you do not seem to have any video devices available. If your card is not supported by Video4Linux then it's a bit of a non-starter. Even if it is supported you may need to manually create your video devices and/or add options to /etc/modules.conf or /etc/modprobe.conf to get it to function correctly.
Phil
Posted: Fri Jun 10, 2005 3:43 pm
by aot2002
could you tell a bit more on how to do this?
im not sure how to manuelly create video devices ?
or where could i find this info?
Posted: Fri Jun 10, 2005 10:38 pm
by zoneminder
It's really a bit outside the scope of ZM as it's to do with Video 4 Linux in general. I'll ee if I can find a good guide to it and post it here.
Phil
Posted: Sat Jun 11, 2005 2:49 pm
by aot2002
i really appriceate that phil
ive bought a card and i love ZM this ones for my home system and now i cannot use my cameras, i'd struggle to get this work since i paid for the card already.
i await your reply.
Posted: Sat Jun 11, 2005 8:32 pm
by cordel
Hi Jay,
I didn't find much at all for drivers for that card. I found one guy that had tried a few years back on one of the earlier chips and only managed to get PAL working without many options :( As of right now I am good at modifing and tweaking things but developing a new driver is beyond me at this date.
Regards,
Cordel
Posted: Sun Jun 12, 2005 3:27 am
by aot2002
ouch !
bummer a waste of money i'll try and post it back on ebay.
Posted: Thu Jun 16, 2005 7:17 pm
by aot2002
would either of you two want to try getting this card working if i sent the card to you?
I'll pay for the shipping to you and just let you keep it.
Please let me know if your interested in making it work, in return i get a way to get this card working ?
Posted: Thu Jun 16, 2005 7:35 pm
by cordel
I wish I could but I have a ways to go before being able to develop drivers. Phil might but you best bet would be to get on the V4l mailing list and making the offer to someone there. Or better yet if you look in the kernel source I think it under /drivers/media/video I think there is some contact info and that would be your best bet.
bttv-cards.c
this file has configuration informations - card-specific stuff
like the big tvcards array for the most part
Copyright (C) 1996,97,98 Ralph Metzler (rjkm@thp.uni-koeln.de)
& Marcus Metzler (mocm@thp.uni-koeln.de)
(c) 1999-2001 Gerd Knorr <kraxel@goldbach.in-berlin.de>
Posted: Fri Jun 17, 2005 1:28 am
by aot2002
ok thanks cordel,
Phil would you like this card to try and get it working ?
Posted: Fri Jun 17, 2005 12:54 pm
by zoneminder
Thanks for the offer. Currently I don't have a system to stick another card in though. My devt box (actually my only box!) is a bit full at the moment.
If it's not recognised as a bttv card then I'd be a bit stuck as well. I've written drivers before but one as big as bttv would be a bit of a major enterprise. If you don't know what else to do with it then by all means mail it to me and I'll see if I can fit it in somewhere but possibly not in the short term.
Cheers
Phil
Posted: Fri Jun 17, 2005 3:33 pm
by aot2002
ok sounds like more grief then worth it
thanks though
