nice still, streaming is dark
I got everything setup so I can see a nice still in the browser, but the streaming display is dark. I have ffmpeg installed. do I need anything else in terms of codec or player to see streaming video?
is there a place where I dictate what kind of streaming encoding (MJPEG, MPEG, etc.) to use?
When you say it's dark are you refering to that it is darker than the jpeg still or do you mean it is black and not displaying?
Windows Media player also takes up to 15 seconds to buffer the image before it will display and on a linux machine you would have to install something like mplayer to see the stream.
Firefox supports mjpg natively so you could disable mpg streaming and ZM will send mjpeg to mozilla based browsers.
You can also use cambozola to recieve mjpeg in IE.
I found zmdc.log in /tmp. here are some errors
Server starting at 05/06/11 08:49:25
Can't find process with command of 'zmtrack.pl -m 12'
Can't find process with command of 'zma -m 12'
Can't find process with command of 'zmc -d 0'
'zmc -d 0' started at 05/06/11 08:52:24
'zmc -d 0' starting at 05/06/11 08:52:24, pid = 14500
'zmc -d 0' crashed at 05/06/11 08:52:24, exit status 255
'zmc -d 0' starting at 05/06/11 08:52:24, pid = 14504
Can't select: No child processes at /usr/local/bin/zmdc.pl line 593.
Server starting at 05/06/11 08:52:24
Can't find process with command of 'zmtrack.pl -m 13'
Can't find process with command of 'zma -m 13'
what do they mean?
what do they mean?
- zoneminder
- Site Admin
- Contact:
I saw a lot of
zmu[16357]: ERR [Can't shmget, probably not enough shared memory space free: Invalid argument]
so I increased shmall and shmmax to 134217728.
now I see this
zms[7065]: ERR [Shared memory not initialised by capture daemon]
the /dev/video1 remains red, and no still nor stream images.
has anyone seen this before?
now I see this
Lot of times. If you do a search you'll get 2 pages worth.
This may be because the capture daemon hasn't been started or may be because it crashed before it could initialise it. Check in zmdc.log for example to see if it is being restarted, or look for earlier errors in the messages file.
See this thread may help:
http://www.zoneminder.com/forums/viewto ... ure+daemon
and
Regards,
Cordel
and
Regards,
Cordel
well, first zmu -d 0 -q -v failed, it says
Error, failed to open video device: No such device
the list of video devices has permission set as
linux:/dev # ll vid*
lrwxrwxrwx 1 root root 6 Jun 2 10:42 video -> video0
crw----rw- 1 bruce video 81, 0 Mar 19 11:36 video0
crw----rw- 1 bruce video 81, 1 Mar 19 11:36 video1
crw------- 1 bruce root 171, 16 Mar 19 11:36 video1394
crw----rw- 1 bruce video 81, 2 Mar 19 11:36 video2
crw----rw- 1 bruce video 81, 3 Mar 19 11:36 video3
do these look ok? or do they indicate some permission problem causing zmu to not find video0?
I changed the u&g of video to bruce:video, now zmu -d 0 -q -v gets
Video Capabilities
Name: BT878 video (ProVideo PV143)
Type: 171
Can capture
Can tune
Overlay onto frame buffer
Can clip
Scalable
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 1 Attributes
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 2 Attributes
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel 3 Attributes
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
but /dev/video0(0) on console is still red, and no image is displayed.
Video Capabilities
Type: 171
Can capture
Can tune
Can clip
Scalable
Video Channels: 4
Audio Channels: 0
Maximum Width: 924
Maximum Height: 576
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel: 0
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 1
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 2
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Channel: 3
Flags: 2
Channel has audio
Type: 2 - Camera
Format: 0 - PAL
Well heres mine on FC3
lrwxrwxrwx 1 root root 6 May 18 14:47 /dev/video -> video0
crw----rw- 1 root root 81, 0 May 18 14:47 /dev/video0
crw----rw- 1 root root 81, 1 May 18 14:47 /dev/video1
crw------- 1 root root 81, 1 May 18 14:47 /dev/video4linux
not sure how your name got in there as the owner or why video is the group unless you changed the root user to bruce.
strange, after I changed the symlink owner to bruce, zmu started to see the video device. I thought that was the problem.
in any case, I restarted zm, and now still image is showing fine again.
but still no stream image. why and when would still show but not stream? can't be the zmc problem anymore, right?
