Page 1 of 1
keeping events
Posted: Sun Jun 12, 2005 4:04 pm
by jameswilson
If an event happens and i want to store it on dvd cd etc how do i go about this
Posted: Tue Jun 14, 2005 2:13 am
by cordel
There are may ways to accomplish this depending on what utilitys you have installed on the machine. ZM does not have a interface as of yet (Is on the wish list though) to do it.
You can use any of the programs that burn CD's like cdrecord, and Kb3.
Kb3 is pretty good if you don't like command line that cdrecord uses.
I have started (planning stage now) setting a lay out that would allow you to select the events you want from the web interface and it would send the events and folders, generate an html page of the database info (so you still have the feel of zm event log) to a folder so that it can be burned to CD or zip/tar and downloaded to be burned. A few other things would be have it converted to mpg so that it's more compact but then I like the JPeg as it holds more detail (would be an option and the user could decide).
Would also be able to use cambozola server to stream the jpegs to the client hopefully but not sure if this is even possible without a webserver but non the less something I'll be looking at.
So it is in planning but I have some paying projects not releated to ZM that take presidence so maybe by the end of the year I'll have the first release to test out.
Regards,
Cordel
Posted: Tue Jun 14, 2005 8:23 am
by zoneminder
There is an 'export' feature in 1.21.1. It might help you do what you are after.
Phil
Posted: Tue Jun 14, 2005 9:50 am
by jameswilson
Yeah it might where does it export it too?
*edit*Opps just noticed im on 1.21.0 thats why i couldnt find it sorry
SOunds great
Posted: Sat Jun 25, 2005 5:16 pm
by jameswilson
if i click on export and tick all the boxes it fails and says 'export faile' there is another php error i think about failing to create directory
Exporting
Warning: opendir(events/New/578): failed to open dir: No such file or directory in /var/www/html/zm/zm_export_funcs.php on line 196
Warning: fopen(events/New/578/zmEventDetail.html): failed to open stream: No such file or directory in /var/www/html/zm/zm_export_funcs.php on line 213
Can't open event detail export file 'zmEventDetail.html'
Posted: Sun Jun 26, 2005 2:39 am
by cordel
From upgrading throught the versions the folders are the camera ID and now there is a symlink that has the camera name pointed to the corrasponding ID that is missing for you. If you add the symlinks you will find that the export function will work.
The other option would be to go into the exportfunctions.php file and chaange all the variables to use the monitor ID instead of the name.
You will find this is really easy.
In what ever editor your comfortable with open zm_export_funcs.php
at line 194 change the following
		$event_path = sprintf( "%s/%s/%d", ZM_DIR_EVENTS, $event['MonitorName'], $event['Id'] );
TO this
		$event_path = sprintf( "%s/%s/%d", ZM_DIR_EVENTS, $event['MonitorId'], $event['Id'] );
Phil, maybe this should be commited into the code as the event names were the old way and now we're useing the key from the database.
Cheers,
Cordel
Posted: Sun Jun 26, 2005 10:06 am
by jameswilson
Thanks Cordel I have changed this as above but i get this
Exporting
Warning: opendir(events//681): failed to open dir: No such file or directory in /var/www/html/zm/zm_export_funcs.php on line 196
Warning: fopen(events//681/zmEventDetail.html): failed to open stream: No such file or directory in /var/www/html/zm/zm_export_funcs.php on line 213
*edit oops id is case sensitive chaged that and i dont get the error anymore
