2tomcats wrote:
I've tested 2 of these wireless cams some time ago. Both had the same problems:
a) After some time (between 30 minutes and 5 hours) they stopped responding and must be resetted.
Hmmm do you know if it was a wireless problem, or the camera itself crashed? If just a wireless problem then it won't matter as I intend to use the wired versions.
b) FPS was around _3_ (three) with ZM, never tested the Windows software.
3FPS? ouch. Something must be wrong there, even crappy USB cameras get better than that...then again maybe this is the nature of any IP camera (because it has to send http requests for the images)?
c) the picture quality is ok as long as there is enough light. As soon as it gets darker, the picture became b/w and _very_ coarse grained.
Yeah when it gets dark it goes into night mode (turns on IR LEDs and switchs to black and white).
A reference:
Among others i use a really good (but old) surveillance camera with an external RF module (so also a kind of wireless device
But you still have to supply power to the camera right? So not truly wireless
With the good camera i was able to read a cars' licence plate which was 10 meters away. With the 'bad' one i could hardly see the car.
This was during the night (dark), the scene was illuminated with a 500 W halogen flooder mounted above the cameras.
Yeah I would agree that a decent CCD camera is much better quality than any USB or typical "IP/Network" cameras.
I don't know about the wired cams you mentioned, but i don't think that they differ from the wireless ones reagarding the picture quality.
They are exactly the same except for being wired instead of wireless, so yeah picture quality is probably the same.
So my hint is, save some money and buy really good cams. On the long run, this is _much_ cheaper.
Yeah I think you are right. I was trying to go a different route than having a dedicated capture card with the BNC connectors etc...Network cameras seemed like a good solution, but alas I dont think they will give good FPS, and most network cameras have poor image quality as they are meant for indoors and/or optimum lighting conditions.
