Page 1 of 1
can show more than 2 channels
Posted: Mon Jun 13, 2005 9:35 pm
by bhomass
I have a four channel capture card. I set up one monitor each. right now all dev (chan) show orange. but I can only pull up 2 monitor screen at a time. addition screen remains blank.
I already increased shmmax to 134217728.
Posted: Tue Jun 14, 2005 1:12 am
by bhomass
did I confuse anyone? what I meant was I CAN NOT display more than 2 monitors at at time. the 3rd and 4th shows a blank html page.
Posted: Tue Jun 14, 2005 1:39 am
by cordel
Which browser ?
For Firefox or mozilla do the following :
type about:config in the text area
search for and change :
network.http.max-connections-per-server -> 100
network.http.max-persistent-connections-per-proxy -> 100 network.http.max-persistent-connections-per-server -> 100 browser.cache.check_doc_frequency -> 1
Close the browser and open it again.
For IE you may need an older version of Cambozola. I think I'm using .50
Posted: Tue Jun 14, 2005 3:04 am
by bhomass
I use Firefox. so this means such a modification has to be made on all client desktops then? that certainly adds to the instalation cercern.
well, this fix worked! I got many monitor frames up as well as a montage frame.
