multiple monitors per page
Hi
I saw on the home page, a demo of 4 large monitor screens on one web page. is that done by using large montage size or is there a way to specify a number of screens per page?
- zoneminder
- Site Admin
- Contact:
I am referring to the http://www.zoneminder.com/typo3temp/d04c3d20be.jpg screen.
is this a montage view with montages set to a large size?
- zoneminder
- Site Admin
- Contact:
All the cameras have to be set to some thing besides none for the function. If that is not it a setting or few in the groups (top left says n Monitors) if you added any might need to get changed.
Here are two documents you should read that will get you more familuar with ZM.
http://www.zoneminder.com/fileadmin/dow ... zm_manual/
http://www.zoneminder.com/fileadmin/dow ... EADME.html
Regards,
Cordel
Regards,
Cordel
- zoneminder
- Site Admin
- Contact:
ok, I know the symptons now.
when I select NONE for monitor group, then montage shows all four.
if I define new groups with 4, or 3 of the monitors, then click montage, then it only displays the first monitor. the console does agree with the group selection. another words, if I select the 3 monitor group, then the console only shows the three monitors. why doesn't the montage display follow the selection? is this a bug?
- zoneminder
- Site Admin
- Contact:
