How to BTTV card + IR Camera via composite cable
zoneminder
Site Admin
Re: How to BTTV card + IR Camera via composite cable
Post by zoneminder »
Hi Truelies,
I'm not completely sure what you mean when you say you want to 'configure' the card. There's usually not much configuration to be done except sometimes to set up the modules.conf file to load the correct drivers.
Can you tell me which card you are using? It may be one I have used already and know the config for.
Cheers,
Phil,
