1.21.1 doesn't build
bhomass
Post by bhomass »
I am building 1.21.1 from scratch. I am not upgrading from 1.21.0 because of all the problems I had with that version.
I ran ./configure --with-mysql=/usr --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-webuser=wwwrun --with-webgroup=www just like before. Configure went fine.
when I type make. I got
In file included from zmc.cpp:24:
zm.h:28:23: zm_config.h: No such file or directory
I checked repeated. also ran tar again from the download. but indeed this file z._config.h does not exist in src/ directory. didn't anyone else have this problem?
zoneminder
Site Admin
Post by zoneminder »
I think you maybe forgot to run zmconfig.pl after configure?
Phil
bhomass
Post by bhomass »
haha, you are right.
I did a shortcut that did not work. I tried coping the Mconfig.txt over to bypass the lengthy zmconfig.pl.
zoneminder
Site Admin
The best shortcut to do, is to just copy zmconfig.txt over to your new build directory and then run zmconfig.pl -noi which will just run straight through and not ask you any questions.
Phil
