ZM 1.21.0 strange crash
Inferno
Post by Inferno »
with ZM occurs strange crash....
system freeze, not answer,
in log - nothing :(
after reboot ZM can't runing....
in zmpkg.log:
Can't connect: No such file or directory at /usr/local/bin/zmdc.pl line 159.
Executing: /usr/local/bin/zmdc.pl start zmaudit.pl -d 900 -y
Can't open log file: Permission denied at /usr/local/bin/zmdc.pl line 167.
Executing: /usr/local/bin/zmdc.pl start zmwatch.pl
Executing: /usr/local/bin/zmdc.pl start zmupdate.pl -c
see image:
system:
FC3. 2.6.9-1.667
on board 3xFlyVideo 98EZ
what is this?
best regards,
Sergej.
cordel
Post by cordel »
Try checking your permisions
All the binary should be
-rwxr-xr-x  1 root root 178276 Jun 14 21:39 zma
-rwxr-xr-x  1 root root  12361 Jun 22 10:47 zmaudit.pl
-rwxr-xr-x  1 root root 181508 Jun 14 21:39 zmc
-rwxr-xr-x  1 root root  10938 Jun 14 21:39 zmcontrol-axis-v2.pl
-rwxr-xr-x  1 root root   7448 Jun 14 21:39 zmcontrol-kx-hcm10.pl
-rwxr-xr-x  1 root root  12713 Jun 14 21:39 zmcontrol-pelco-d.pl
-rwxr-xr-x  1 root root  12879 Jun 14 21:39 zmcontrol-pelco-p.pl
-rwxr-xr-x  1 root root  15332 Jun 14 21:39 zmcontrol-visca.pl
-rwxr-xr-x  1 root root  16347 Jun 14 21:39 zmdc.pl
-rwxr-xr-x  1 root root 188900 Jun 14 21:39 zmf
-rwxr-xr-x  1 root root  29005 Jun 14 21:39 zmfilter.pl
-rwsr-xr-x  1 root root  79885 Jun 14 21:39 zmfix
-rwx------  1 root root   1002 Jun 14 21:39 zminit
-rwxr-xr-x  1 root root   9341 Jun 14 21:39 zmpkg.pl
-rwxr-xr-x  1 root root   7893 Jun 14 21:39 zmtrack.pl
-rwxr-xr-x  1 root root  11880 Jun 14 21:39 zmtrigger.pl
-rwxr-xr-x  1 root root 194276 Jun 14 21:39 zmu
-rwxr-xr-x  1 root root  12973 Jun 14 21:39 zmupdate.pl
-rwxr-xr-x  1 root root   9116 Jun 14 21:39 zmvideo.pl
-rwxr-xr-x  1 root root   6074 Jun 14 21:39 zmwatch.pl
Your Logfiles should be
(of coarse this is Distro spacific) and I noticed zmupdate.log is differant and I'm not sure why but am looking into it. The user and group should be the same as the user and group set in apache.
-rw-r--r--  1 apache apache 18834605 Jun 22 18:52 zmaudit.log
-rw-r--r--  1 apache apache  1971687 Jun 22 10:50 zmdc.log
-rw-r--r--  1 apache apache  1674185 Jun 22 10:50 zmfilter.log
-rw-r--r--  1 apache apache    78512 Jun 22 10:50 zmpkg.log
-rw-r--r--  1 apache root          0 Jun 14 21:48 zmupdate.log
-rw-r--r--  1 apache apache    52481 Jun 14 09:59 zmvideo.log
-rw-r--r--  1 apache apache   596081 Jun 22 10:50 zmwatch.log
Baylink
Post by Baylink »
Naw, that's a broken driver, a driver that no longer matches a recently upgraded kernel, or a hardware failure.
Inferno
Post by Inferno »
thanks all,
i check files permissions - all ok.
problem with start ZM has been solved by remove all ZM log-files.
after that ZM normal starting.
best regards,
Sergej.
Baylink
Post by Baylink »
FWIW, no, a kernel panic has *nothing* to do with logfiles, permissions, or anything else.
You have an intermittent in your hardware, and it will likely bite you again; mark my words. :-)
