UI for ZoneMinder and mpeg montage/record
Posted: Sat Jun 25, 2005 2:15 pm
Hi everybody...
has been a long time since my last post... im sorry for that !
People, i have two questions...
first, my montage with mpeg system was a total disaster... it simply didnt work as it should, each camera were by default delayed 3 seconds. until this point, no problem.... but after some time
(five minutes or less) the "sync" of the cameras simply breaks down !.. one camera have the default 3 seconds of delay, one other have 8 seconds, another 10 seconds... the system simply gets DUMB and everything ive tried to make the "sync" still working just failed... i know this is not impossible, all standard comercial dvrs do that !. I want to try a little more, (see that the montage itself is not a problem... but the growing delay sync issue is). I intend to make a LOCAL version of zoneminder that also has the actual web version for remote viewing.
I know another user in another forum section have started a message about this, but as i can see he didnt started the project.
Well, another thing is the MPEG4 direct record... Sure this is NOT a extremely necessary feature...but this would be very good.... as i can see it dont really need to capture and record directly in mpeg4, it can capture in jpeg (as it actually does) and after the event is considered "finished" it launches a script to make a mpeg4 of that event.... THE ONLY problem is that the web interface doesnt have the structure to deal with mpeg4 files... statistics, "per frame" view mode and others wouldnt be available. but on other hand you could have a higher FPS system per camera and at a better quality with the same or eve less disk space...
As i can see this is simple to make, i just dont know where to start... i would like any sugestion of you all about this...
Oh. Another project i've already started is a Graphical CDburner for Zoneminder... It actually is beta and need some more development, but i think within two weeks i will have something stable... for instance ive created a script that searches the databases for "archived" Events, and creates a link to each one in directory /cdrec. Then i map webcdwriter to the directory /cdrec. i run webcdwriter from a link (shortcut) in my graphical desktop... the shortcut runs the "identifier" script before webcdwriter, this ensure webcdwriter will aways have a direct way to get the "archived" events, this turns webcdwriter in a much more simple cd-writting component for zoneminder. This is ready and works well, i will post it in a day or two in User Contributions section.
Well, Philip, i want to know about what do you think of all this... do you think a mpeg4 "automatic conversion" version of zoneminder would be useful ? and theother users in this forum... i think it would be a fast way to add a GOOD feature to zm... and the web interface could have an option ZM_AUTO_MAKE_MPEG_FROM_EVENTS that disable features like the per frame view or statistic and let you use mpeg 4. much easier than writing a complex way to record direct in mpeg4.
And about the mpeg montage... do you know what does it could be ? ive tested in asf and wmv protocols and same thing occurred. this is easy to reproduce... select MPEG mode for viewing, open two windows one for each camera and wait something about 15 minutes... you will issue that.
I would like to use the h263 protocol (as ive said in old post) because making tests with it, it is a very good protocol for video transmission, very fast even on low bandwidth links. it simply doesnt show the video. If someone have tried another format and had success, please tell me.
Really thank you all for liste to me.
Victor Diago
Victor Diago
