Frontend for Windows work with multiply ZM servers
Inferno
Post by Inferno »
Alpha-version of my simple Frontend ZM for Windows
Frontend work in Windows XP, 98, ME, 2000
Tested in: PII-266, 32mb ram
request screen size 1024x768
work with ANY version of ZM
Frontend can work with 1-10 ZM servers simultaneously.
Download here:
http://syr.nnov.ru/ZMFE.zip this is alpha-version.
Instructions how to install:
1. extract archive ZMFE.zip.
2. copy ZMFE/web/*.php to folder of web server, where ZM php scripts installed
3. Create directory "C:\1"
4. Create on each ZM server user, who was allow to get stream image
BEFORE run feZM.exe FIRST NEED configure feconf.ini
after that you can run feZM.exe.
Enjoy. :)
best regards,
Sergej.
cordel
Post by cordel »
Nice job, and thank you for your contrib I'll have to see if I have a windoze machine laying around anywhere and check it out. :D
fernando
Post by fernando »
seems very nice
but will great if you put the source code so ppl can enance it.
and add some lenguage features.
Fernando
dmit
Post by dmit »
Tak chto naschet ishodnikov? Zabavnaja softinka poluchilas, hotelos bi ee dorabotat' napilnikom :)
jameswilson
Post by jameswilson »
just what i was thinking lol
dmit
Post by dmit »
What you mean? :)
I just wrote the translation of fernado's message in Inferno's native language, 'cause am also interested in getting the source.
jameswilson
no offence meant i just didnt have a clue what it meant ;). Im not interested in source as i cant do anything with it, good luck to those that can. I am interested in this too.
James
acrid
problems with plain authentication
Post by acrid »
for some reasons i can't use zm with hashed authentication since upgrading to 1.21.3
that's why this frontend didn't work for me.
"hashed=N" didn't help either.
so i changed the last lines in fe_login.php into:
echo 'AUTH:';
$auth=authHash();
if (!$auth)
                echo "none";
                echo "&user=";echo $username;
                echo "&pass=";echo $password;
else
                echo $auth;
//$username && $password
I'm not sure if it stills works with hashing, because i can't test it.
cheers
p.s. may anyone explain the buttons within the frontend? only "?????" for me. an english version or the source code would help even more ;)
