Page 1 of 1
Camera unplugged = nothing recorded?
Posted: Mon Jun 27, 2005 5:00 pm
by blaxer
I have been using ZM for a couple of days now and everything seems to be working great. I was watching one of my cameras in real time (by connecting to it's internal web server) which usually does not effect ZM in any way. While watching the video in "real-time" I saw my cat walk over to the camera and grab the power cord and pull it out, which I thought was hillarious until I checked ZM. ZM had an event recorded for the camera but it was labeled "new event" 0 seconds, no video, no stills, nothing. How can this be? I mean it took at least 20 seconds for the cat to make it across the room, all of which time ZM would normally be recording. Any ideas?
TIA!
Blax...
Posted: Mon Jun 27, 2005 5:42 pm
by jameswilson
if you wait till the end of your section time (default 600 seconds) you should have the event
Aha!
Posted: Mon Jun 27, 2005 5:53 pm
by Baylink
It's the *section* time. Is that true of mocord and record modes as well?
Posted: Mon Jun 27, 2005 6:35 pm
by cordel
From the Readme:
Section Length – This specifies the length (in seconds) of any fixed length events produced when the monitor function is ‘Record’ or ‘Mocord’. Otherwise it is ignored. This should not be so long that events are difficult to navigate nor so short that too many events are generated. A length of between 300 and 900 seconds I recommended.
Chears,
Cordel
Posted: Mon Jun 27, 2005 10:54 pm
by jameswilson
yeah it is but i assume if you use 'modect' then it would be in the list quicker. Bear in mind most of the time you watch recordings after the event. although you may have a serial 'cat burglar' there
Posted: Wed Jun 29, 2005 1:41 am
by blaxer
LOL thanks for the replies, I rebooted the machine last night and it did come up...
