Disk space...
blaxer
Disk space...
Post by blaxer »
I did search for this I promise, didn't come up with anything which might be my searching skills, easy question though, I think. What happens when ZM runs out of disk space? I'm hoping it will just overwrite the earliest events???
TIA!
cordel
Post by cordel »
See the last paragragh for Filering Events
http://www.zoneminder.com/fileadmin/dow ... c107202205
or this topic here
http://www.zoneminder.com/forums/viewto ... ight=purge
This should get you going.
If your useing a single drive (not dedicated for events) you don't want it to fill up and should have atleast 5%. If it fills you will find the machine unresponcive.
Regards,
Cordel
blaxer
Post by blaxer »
Excellent, thanks so much!
