Page 1 of 3
Temp demo site
Posted: Mon Jul 04, 2005 8:34 pm
by jameswilson
If anyone is looking at zm and wants to know how it works ive put my box open to public access. (temp for now but i wont take it down unless i have to). Now bear in mind im on std 512 braodband in the uk and that only gives me 256k upstream. My ip is a wan address and as such i think it only works in the uk
ip = 217 dot 154 dot 74 dot 22/zm/
This is a stock live cd install
I have 3 cams on it 2 on the front drive and another in the loft ready to be fitted to the rear.
The box is headless in my loft.
FYI its a athlon 2800+ (my pc "borrowed" from work)
512Mb shared graphics
30Gb disk
cams are a day night bullet with ir, std discreet mono and a cheapy dome.
I will be adding a ptz dome just to play with so when its there its there.
user name guest
pass zmisgreat
Any probs let me know
James
Posted: Mon Jul 04, 2005 11:30 pm
by rdmelin
Thanks James,
You might look at masking out the upper corners of the Vista monitor. You're getting alot of alarm activity there.
Ross
Posted: Mon Jul 04, 2005 11:41 pm
by jameswilson
pesky spiders!!!
Posted: Mon Jul 04, 2005 11:46 pm
by jameswilson
pesky spiders!!!
TY ros i will well impressed. I downloaded cd burnt it stuck it in, pressed a few buttons, and wow i had a workmg zm. Great work mate. For us linux idiots makes life so easy. thankyou. Oh and with the activity did you mean the webs or the neighbours lol..
James cheers again
Posted: Fri Jul 08, 2005 3:17 pm
by jameswilson
Oh btw cheers to you all for trying to hack into my box, wasnt what i put it up here for. BTW appache logs ip's....
Posted: Fri Jul 08, 2005 3:28 pm
by jameswilson
remelin
Out of interest if my ip is a wan address how did you get into it?
Posted: Fri Jul 08, 2005 10:33 pm
by cordel
Because the WAN addres is the public address (wide area network) that is on the internet. Anyone can get to it. I hope you have a good firewall
Posted: Tue Jul 12, 2005 9:09 am
by fcrossen
Login above does not work now...
BTW: Anyone looking for a firewall - look at webmin.com and install. Then install the turtlefirewall.com plugin. Very good!
Posted: Tue Jul 12, 2005 9:16 am
by jameswilson
i just tried ot from work and i can get in with those login details. Are you using all lower case. Plus further info i have removed a camera because all it was doing was recording my loft.
James PM if you still cant get in? (I think you need to enable cookies too)
Posted: Tue Jul 19, 2005 4:09 pm
by Dirky
thanks james, nice to see a working setup. I'll check back tonight when it is darker to see how the cameras are performing.
thanks
Mike
Posted: Tue Jul 19, 2005 10:35 pm
by jameswilson
no probs mike hope it helps you.
Posted: Tue Jul 19, 2005 11:07 pm
by cordel
I also have mine back avalible to peek at:
http://cordel.no-ip.info:8080
User: guest
Pass: guest
The cameras are PC164C-EX from supercircuits.com
http://www.supercircuits.com/index.asp? ... rodID=4167
One has a 4mm pinhole lens (Driveway)
One has 5-50mm ajustable lens (court) Sometimes looks washed out due to setting on window ledge and cathes reflection off the window.
Both lenses have a DC auto iris.
Cheers,
Cordel
Posted: Sat Jul 23, 2005 9:17 am
by JasonH
Wow, that works fast Cordel. What's your upstream bandwidth?
I was just on for a couple of minutes and spotted someone turning a car round at 2:08am (10:08 am where I live ) Event: Driveway-101961.
Incredible, live action at 3fps and 4,690 miles. Thanks for opening up the demo.
Posted: Sun Jul 24, 2005 12:54 am
by cordel
Yeah, No problem. It's just an Althalon XP 2000 with 512MB and 2 Hauppauge 64405
The software is the single CD FC3 distro I put together that I need to find an FTP server with bandwidth to host it (650MB iso). My up is 384kb burst I think but seems constant at just under 256KB. But for one person to download the ISO they are looking at >10hrs download.
I have started doing the same for FC4.
Regards,
Cordel
Posted: Thu Aug 11, 2005 9:51 pm
by sgtdawg
is there anyway you could set up a torrent to get the single CD FC3/4 distro out?
