Level One http://www.level-one.com.au/display.asp?productid=230
Make some really nice looking cameras at reasonable prices, does anyone have these working with ZoneMinder? And if so what's the URL to the JPEG file for ZoneMinder?
Regards,
Speegs
Level One Cameras
Level One Cameras
LevelOne Support sent me this email, some of their cameras it seems may work, but some of the new MPEG based ones do not at the moment. Hope this helps others looking at LevelOne Cameras.
Dear Sir:
Sorry, these two models can not support viewing snapshots(jpg) by certain URL .
Our other models can do like FCS-1010, WCS-2010, FCS-1030/40 and WCS-2030 .
Best Regards
LevelOne Support
Dear Sir:
Best Regards
LevelOne Support
- zoneminder
- Site Admin
- Contact:
Settings for LevelOne FCS-1030
I try to add a LevelOne FCS-1030 cam to my zoneminder and it didn't work.
Can anyone send me the settings?
(My browser works with "x.x.x.x/cgi-bin/image.jpg" but ZM do not. User/Pass is disabled).
Greetings,
Axel
Greetings,
Axel
Level One Cameras
I didn't end up getting the jpeg based level 1 cameras, I ended up with a Netcomm (Works well).
Contact level 1 support they seem helpful. If the URL works in your browser and displays a static jpeg I couldn't see why it wouldn't work with Zoneminder, maybe you need to set a username and password.
Regards,
Speegs
Regards,
Speegs
LevelOne FCS-1010 PAN/TILT support
Will work this camera fully with ZM ?
Will work PAN/TILT ?
Level One FCS 1040
I have got the Level One FCS-1040 working (... without the PTZ at this stage). It gives a pretty good picture. Will be working on the PTZ aspect this weekend. Will report back on success with settings and a copy of the script.
Jerji
Jerji
Success PTZ FCS-1040 :-)
Got the basic PTZ working for the FCS-1040. Pan, Tilt, Zoom, Iris, Focus all going but I ran out of time to finish the script (pan speed, patrol, etc). Will work on it again in the next weeks and then post the script and a howto (sorry but I only get a couple of hours each week to get access to this system).
Main thing is, it integrates with ZM nicely
Well done to the ZM developers, as it was not too difficult to follow the instructions (and yes I did RTFM
Code for level1 1040 ptz
It's not yet finished (a few more things could be added, but time is tight). Hope this helps someone. And BTW I just tweaked someone else's code so I cannot take much credit!
Regards
jerji
#!/usr/bin/perl -wT
# ZoneMinder Panasonic IP Camera Control Script, $Date: 2006/05/08 12:37:48 $, $Revision: 1.5 $
# Copyright (C) 2003, 2004, 2005, 2006 Philip Coombes
# This script continuously monitors the recorded events for the given
# monitor and applies any filters which would delete and/or upload
# matching events
# This control script was modified by Ian Macintosh to work with the Level1
# 1040 PTZ cameras.
# August 2007
# All care, no responsibility. ;-)
use strict;
# These are the elements you can edit to suit your installation
use constant DBG_ID => "Level1_pzt_control"; # Tag that appears in debug to identify source
use constant DBG_LEVEL => 0; # 0 is errors, warnings and info only, > 0 for debug
use ZoneMinder;
use Getopt::Long;
$| = 1;
$ENV{PATH} = '/bin:/usr/bin';
$ENV{SHELL} = '/bin/sh' if exists $ENV{SHELL};
delete @ENV{qw(IFS CDPATH ENV BASH_ENV)};
sub Usage
print( "
Usage: pzt_control.pl <various options>
exit( -1 );
zmDbgInit( DBG_ID, level=>DBG_LEVEL );
my $arg_string = join( " ", @ARGV );
my $address;
my $command;
my ( $speed, $step );
my ( $xcoord, $ycoord );
my ( $width, $height );
my ( $panspeed, $tiltspeed );
my ( $panstep, $tiltstep );
my $preset;
my $autostop;
if ( !GetOptions(
'address=s'=>\$address,
'command=s'=>\$command,
'autostop=f'=>\$autostop,
'speed=i'=>\$speed,
'step=i'=>\$step,
'xcoord=i'=>\$xcoord,
'ycoord=i'=>\$ycoord,
'width=i'=>\$width,
'height=i'=>\$height,
'panspeed=i'=>\$panspeed,
'tiltspeed=i'=>\$tiltspeed,
'panstep=i'=>\$panstep,
'tiltstep=i'=>\$tiltstep,
'preset=i'=>\$preset
Usage();
if ( !$address )
Usage();
if ( defined($autostop) )
# Convert to microseconds.
$autostop = int(1000000*$autostop);
Debug( $arg_string."\n" );
srand( time() );
sub printMsg
my $msg = shift;
my $msg_len = length($msg);
Debug( $msg."[".$msg_len."]\n" );
sub sendCmd
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
use LWP::UserAgent;
my $ua = LWP::UserAgent->new;
$ua->agent( "ZoneMinder Control Agent/".ZM_VERSION );
#print( "http://$address/$cmd\n" );
my $req = HTTP::Request->new( GET=>"http://$address/cgi-bin/$cmd" );
my $res = $ua->request($req);
if ( $res->is_success )
$result = !undef;
else
Error( "Error check failed: '".$res->status_line()."'\n" );
return( $result );
sub moveUp
Debug( "Move Up\n" );
sendCmd( $cmd );
if ( $autostop )
usleep( $autostop );
stop();
sub moveDown
Debug( "Move Down\n" );
sendCmd( $cmd );
if ( $autostop )
stop();
sub moveLeft
Debug( "Move Left\n" );
sendCmd( $cmd );
if ( $autostop )
stop();
sub moveRight
Debug( "Move Right\n" );
sendCmd( $cmd );
if ( $autostop )
stop();
sub setSpeed
Debug( "Set Speed\n");
my $cmd = "camctrl.cgi?speedpan=$panspeed";
sendCmd( $cmd );
sub stop
Debug( "STOP\n" );
my $cmd = "camctrl.cgi?auto=stop";
sendCmd( $cmd );
sub zoomTele
Debug( "Zoom Tele\n" );
sendCmd( $cmd );
if ( $autostop )
stop();
sub zoomWide
Debug( "Zoom Wide\n" );
sendCmd( $cmd );
if ( $autostop )
stop();
sub focusFar
Debug( "Focus Far\n" );
my $cmd = "camctrl.cgi?focus=far";
sendCmd( $cmd );
if ( $autostop )
stop();
sub focusNear
my $cmd = "camctrl.cgi?focus=near";
sendCmd( $cmd );
if ( $autostop )
stop();
sub focusAuto
Debug( "Focus Auto\n" );
my $cmd = "camctrl.cgi?focus=auto";
sendCmd( $cmd );
sub irisOpen
Debug( "Iris Open\n" );
my $cmd = "camctrl.cgi?iris=open";
sendCmd( $cmd );
if ( $autostop )
stop();
sub irisClose
my $cmd = "camctrl.cgi?iris=close";
sendCmd( $cmd );
if ( $autostop )
stop();
sub irisAuto
Debug( "Iris Auto\n" );
my $cmd = "camctrl.cgi?iris=auto";
sendCmd( $cmd );
sub focusAuto
Debug( "focus Auto\n" );
sendCmd( $cmd );
if ( $command eq "up" )
moveUp();
elsif ( $command eq "down" )
moveDown();
elsif ( $command eq "left" )
moveLeft();
elsif ( $command eq "right" )
moveRight();
elsif ( $command =~m/stop/ )
stop();
elsif ( $command =~ m/tele/ )
zoomTele();
elsif ( $command =~ m/wide/ )
zoomWide();
elsif ( $command =~m/far/ )
focusFar();
elsif ( $command =~m/near/ )
focusNear();
elsif ($command =~m/open/ )
irisOpen();
elsif ($command =~m/close/ )
irisClose();
elsif ($command =~m/iris_auto/ )
irisAuto();
elsif ($command =~m/focus_auto/ )
focusAuto();
else
Error( "Can't handle command $command\n" );
# =======================Physical end of file===============================
jerji
I did just manage to get my FCS 5030 to work (in this thread).
I changed Remote Host Path from
/video.mjpg
to
/cgi-bin/viewer/video.jpg
The setting /video.mjpg I got from L1 webinterface > Advanced > Network where it says
Access name for stream 1 /video.mjpg
What am I missing when I use video.jpg instead? Why doesn't /video.mjpg work?
/video.mjpg
to
