Im trying to setup a filter to do a few things as follows
The machine is setup to 'mocord all cameras'
I want to keep 2 weeks full foptage from all cameras
then footage over 2 weeks old that has an max value greater than 0 i want to 'archive' the rest delete
Im hoping this would give me a reasoanble staorage time without losing all the little bits between alarms etc.
I still want the purge when full which i set at 97%
Is it possible to have half the disk for record and the other half for events only or is that waht 'archive' is for/
James
filters
archive is just a bit in the database that can be set so when you run filters to delete events you don't delete the ones you want to keep. So there is no compresion like youmight think when you see archive. If you look at your defualt PurgeWhenFull filter the first query is select events NOT archived, so this way your events with archive checked do not get selected for deletion even if the rest of the querys in the filter are true.
Regards,
Cordel
Regards,
Cordel
Thats part of the perl date time module and it always gets me confused. It works a little backwards (IMHO) I know I wrote a how to here on the forum but this was all that turned up in my search.
http://www.zoneminder.com/forums/viewto ... ght=filter
But that should get you close to what you want.
you can specify days insted of weeks. Just don't check the delete box till your sure the filter is working right. You can run the query and you should see your oldest events.
Regards,
Cordel
Regards,
Cordel
- zoneminder
- Site Admin
- Contact:
Essentially older than 20 days would be
if I remember correctly (I can't get into my box at the moment to check). It uses quite flexible parsing but it's best to keep it simple.
Phil
Date/Time < -20 day
Phil
