function checklinks($path)
It will return false if the path is not a dir or if it couldn't open the folder.
It will return an array with the name of the symlinks that for some reason couldn't be created.
It will return true if it was able to create all missing symlinks.
# Get from the database Monitors that are configured
$sql = "select Id as MonitorId, Name as MonitorName from Monitors";
$result = mysql_query( $sql ) or die(mysql_error());
while($row = mysql_fetch_assoc( $result ))
$Monitor['id'][] = $row['MonitorId'];
$Monitor['name'][] = $row['MonitorName'];
if(!is_dir($path)) return false;
if(!($dir = opendir( $path ))) return false;
while (false !== ($file = readdir($dir)))
#Get the symlinks
if (is_link($file))
$symlinks[] = $file;
closedir($dir);
foreach ($symlinks as $key=>$value)
if(!in_array($value,$Monitor['name']))
unlink("$path/$value");
unset($symlinks[$key]);
$diff = array_diff($Monitor['name'], $symlinks[$key]);
if(!empty($diff))
foreach ($diff as $key=>$value)
if (!symlink($path.'/'.$Monitor['id'][$key],$value))
#if(!symlink("$path/{$Monitor['id'][$key]}",$value))
$symlinks_not_created[] = $value;
if(empty($symlinks_not_created))
return true;
else return $symlinks_not_created;
I am hoping to have this done and tested by Wednesday night so this can go in the next release. Any input my be useful as I'm drawing a blank.
Cheers,
Cordel
$symlinks=$Monitor['id']=$Monitor['name']=array();
#Get the symlinks
if (is_link($file))
# closedir($dir);
$diff = array_diff($Monitor['name'], $symlinks);
if(!empty($diff))
#if(!symlink($path.'/'.$Monitor['id'][$key],$value))
return true;
closedir($dir);
Now I'm getting
Apache_Error_log wrote:[client 192.168.10.10] PHP Warning: symlink(): Permission denied in /usr/lib/zm/html/zm_export_funcs.php on line 319, referer: http://192.168.10.20/index.php
Okay, Figured it out and here it is.
The top portion is still broken as it is tring to use a full path I think and not relative to the web root as it needs to be.
#Get the symlinks
if (is_link($file))
closedir($dir);
chdir( $path );
unlink("$value");
chdir( ".." );
if(!empty($diff))
chdir( $path );
if(!symlink($Monitor['id'][$key],$value))
#if(!symlink("{$Monitor['id'][$key]}",$value))
chdir( ".." );
return true;
# Get the symlinks currently in the directory
chdir( $path );
if(!($dir = opendir( '.' ))) return false;
while (false !== ($file = readdir()))
#Get the symlinks
if (is_link($file))
chdir( ".." );
# Look for bad links and remove.
chdir( $path );
unlink("$value");
chdir( ".." );
if(!empty($diff))
chdir( $path );
chdir( ".." );
return true;
When the symlinks function broke (at some point in previos version) the links that are used for using the monitor name were not updated when the name changed leaving behind the old and now incorrect link. This script querys the database to see what should exist, removes any rouge links, and creates any missing links
Since the problem was corrected in the latest 1.21.3 source and 1.21.2-3 rpm any new installs would not have an issue. but for some one that had changes the name of a monitor while it was broken and upgraded it would not be fixed. So this is a sanity check so that we're not up here on the board troubleshooting and walking folks how to fix it, and can spend time moving forward and dealing with other issues
Regards,
Cordel
PS This would be my first PHP script so feedback is welcome.
well done looks great, thats about all i can tell you mate, dont even know what php stands for much less write my first one lol. Well done it will be usefull
