apache port
apache port
Is it possible to change the port number that the webserver listens on from 80 to say 82. Reason i ask is that i already have a webserver (a windows 2003 server for remote active sync and webmail) but would like to play with a zm box at work. If the port number was changed to 82 i could port forward 82 to my zm box and away id go. Is this possible with zm or does it expect all requests to be on 80
- krzys31337
You mean:
In your httpd.conf ? (or sth likie: etc/httpd/conf.d/10.httpd.conf)
Or using url for webcam like this: http://my.ip.num.ber:82/some.jpg
Listen :82
