Problems Whit Bttv
andres504
Problems Whit Bttv
Post by andres504 »
Ihave probles for installl bttv drivers.
make -C /lib/modules/2.6.11-1.35_FC3smp/build SUBDIRS=/root/bttv-0.9.11 modules
make[1]: Entering directory `/lib/modules/2.6.11-1.35_FC3smp/build'
CC [M] /root/bttv-0.9.11/bttv-driver.o
/root/bttv-0.9.11/bttv-driver.c: In function `bttv_open':
/root/bttv-0.9.11/bttv-driver.c:2761: error: called object is not a function
/root/bttv-0.9.11/bttv-driver.c: In function `radio_open':
/root/bttv-0.9.11/bttv-driver.c:2897: error: called object is not a function
make[2]: *** [/root/bttv-0.9.11/bttv-driver.o] Error 1
make[1]: *** [_module_/root/bttv-0.9.11] Error 2
make[1]: Leaving directory `/lib/modules/2.6.11-1.35_FC3smp/build'
make: *** [default] Error 2
I am Update of kernel now have kernel 2.6.11-1 in FC3.
cordel
Post by cordel »
Are you installing a vendors drivers?
That kernel already has BTTV drivers included so unless you have drivers for a card from a vendor that would hopefully enhance performance you don't need them.
You should also I beleive place that folder in the source kernels directory as this will not build by its self, you have to rebuild the kernel modules. A google search for making the linux kernel should turn up something.
Regards,
Cordel
andres504
Tahk You...
Post by andres504 »
as I can making the linux kernel should turn up something
I Have 2.6.11-1 it updates it with yum....
Help!!!
cordel
Post by cordel »
What distro (ie... Fedora, Mandrake, SuSe, Debian)?
What does your capture card look like or what brand/model of USB camera?
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
andres504
Post by andres504 »
I am Have Fedora Core3, whit kernel 2.6.11-1
cordel
Post by cordel »
The kernel for fedora core 3 already has the v4l bttv drivers compiled into it so unless you have driver from the card vendor that might work better there is no need to add the drivers in. You should be good to go.
Regards,
Cordel
3939663646337
-Mark Twain
andres504
Post by andres504 »
As I can know if I have installed all the necessary one to use zm?????
My Capturecard is Brokent 878....
i can view the page of zm http://localhost/zm, but i not view the video,
Adding cameras of source /dev/video/0
and in chanels =1
Thank you
TheFluffyOne
Post by TheFluffyOne »
What output do you get from:
modprobe bttv
grep -i bttv /var/log/messages | tail -n 30
andres504
Post by andres504 »
This is the ERROR .....
[root@tie ~]# modprobe bttv
WARNING: Error inserting tveeprom (/lib/modules/2.6.11-1.35_FC3/updates/drivers/media/video/tveeprom.ko): Invalid module format
WARNING: Error inserting btcx_risc (/lib/modules/2.6.11-1.35_FC3/updates/drivers/media/video/btcx-risc.ko): Invalid module format
WARNING: Error inserting v4l2_common (/lib/modules/2.6.11-1.35_FC3/updates/drivers/media/video/v4l2-common.ko): Invalid module format
WARNING: Error inserting video_buf (/lib/modules/2.6.11-1.35_FC3/updates/drivers/media/video/video-buf.ko): Invalid module format
FATAL: Error inserting bttv (/lib/modules/2.6.11-1.35_FC3/updates/drivers/media/video/bttv.ko): Invalid module format
[root@tie ~]# grep -i bttv /var/log/messages | tail -n 30
Jul 21 09:54:39 tie kernel: bt878: Unknown symbol bttv_read_gpio
Jul 21 09:54:39 tie kernel: bt878: Unknown symbol bttv_write_gpio
Jul 21 09:54:39 tie kernel: bt878: Unknown symbol bttv_gpio_enable
Jul 21 09:54:39 tie kernel: bttv: version magic '2.6.11-1.35_FC3 586 REGPARM 4KSTACKS gcc-3.4' should be '2.6.11-1.35_FC3 686 REGPARM 4KSTACKS gcc-3.4'
Jul 21 10:18:45 tie kernel: bttv: version magic '2.6.11-1.35_FC3 586 REGPARM 4KSTACKS gcc-3.4' should be '2.6.11-1.35_FC3 686 REGPARM 4KSTACKS gcc-3.4'
Jul 21 10:18:45 tie kernel: bt878: Unknown symbol bttv_read_gpio
Jul 21 10:18:45 tie kernel: bt878: Unknown symbol bttv_write_gpio
Jul 21 10:18:45 tie kernel: bt878: Unknown symbol bttv_gpio_enable
Jul 21 10:22:12 tie kernel: bttv: version magic '2.6.11-1.35_FC3 586 REGPARM 4KSTACKS gcc-3.4' should be '2.6.11-1.35_FC3 686 REGPARM 4KSTACKS gcc-3.4'
zoneminder
Site Admin
Post by zoneminder »
This looks to me like there is a mismatch between your kernel version and the version that the drivers were built for.
Phil
andres504
My Capture card
Post by andres504 »
I am have a capture card Kodicon 8800, in Fedora c3, with kernel 2.6.9 i am ned update the kernel (2.6.11)
Thank you
