ZoneMinder
cnr0616
ZoneMinder
Post by cnr0616 »
cordel
Post by cordel »
This sounds like fun. Let me now if you need anything special in the RPM to support it. I don't think you will but just in case the offer is there.
Regards,
Cordel
cnr0616
Post by cnr0616 »
zoneminder
Site Admin
Post by zoneminder »
This is an interesting variation. I'm sure we'd all like to hear how you get on!
Phil
cnr0616
Post by cnr0616 »
cnr0616
Post by cnr0616 »
cordel
Post by cordel »
Awesome Craig, Looks really good. You could try an IP cam or if you wish you can stream from my ZM box a couple of cameras just to have something capturing just please be gentle on the fps as I only have 256kb up and this is the same bandwidth as the YUM, ftp, and web server. The user and pass are guest. http://cordel.no-ip.info:8080 Just let me know so I can shut down the remote that I have capturing now at 0.5 fps to reduce the load on my upload.
Phil this would be a nice item to show case some how. My only concern is how hot the xbox can get and I hope you got the new power cord to replace the one that catchs on fire :shock:
Cheers,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
cnr0616
Post by cnr0616 »
cnr0616
Post by cnr0616 »
Ruler
Post by Ruler »
Just an idea that may or may not work is to grab an external IDE->USB drive enclosure to slap your bigger drive into. I believe that it shows up as just another USB mass storage device, similar to a thumb drive, and mounted as /dev/sdan. It'd eliminate the $55 mod chip from the parts list, be more flexible, and only cost $15. :)
I've tried to get that driver working at home a few times for a USB camera, but never have gotten it to compile.
Ruler
Post by Ruler »
Sweet project idea BTW. :)
cordel
Post by cordel »
Hi Craig,
Sorry I haven't forgotten about you, Work it running me 12+ hours a day now. I'll try putting that kernel together in the next couple days.
Regards,
Cordel
cnr0616
Post by cnr0616 »
tux
Post by tux »
Hello
Your project is interesting.
I have a xbox with xebian and two usb ports in controler, I installed xebian without modchip (I used xploit-software), if works your project is posible I test it.
Spca5xx works with zm?, I have a trust spacecam 120 (9€ )when I test with zm I had problems :( .
http://www.zoneminder.com/forums/viewto ... highlight=
I intented with spca5xx, tomorrow I will test with NW802 kernel module
