Syl
Posts: 11 Joined: Mon Jul 25, 2005 7:19 am
Post
by Syl » Mon Jul 25, 2005 7:26 am
Hi !
I have ZoneMinder 1.21.0 running on ZoneMinder Live CD installed on the hard drive.
I had the problem with the shared memory so I've increased it to 256Mb, but now it still doesn't work:
[/home/user]# zmc -m 1
Not a JPEG file: starts with 0x48 0x54
var/log/zm/zmdc.log wrote:
Starting pending process, zmc -m 1
'zmc -m 1' started at 05/07/25 10:24:02
'zmc -m 1' starting at 05/07/25 10:24:02, pid = 5557
'zmc -m 1' crashed at 05/07/25 10:24:04, exit status 1
What should I do now ?
Thanks in advance !
cordel
Posts: 5210 Joined: Fri Mar 05, 2004 4:47 pm
Post
by cordel » Mon Jul 25, 2005 7:44 am
I'm assuming that you are capturing from an IP camera so what maker and model?
Syl
Post
by Syl » Mon Jul 25, 2005 8:21 am
yes, it is a remote camera
It's a SOHO Internet Camera CAS-230/E. It's wireless but I use a cable to connect it to the computer...
cordel
Post
by cordel » Mon Jul 25, 2005 6:06 pm
Unfortunatly they do not have enough information in their manual for me to be able to give you a definative answer.
Go to the cameras web page/ip and If you right click on the streaming image you should see the path. What is the path (X out your IP info)? also when you login to the camera do you get a popup box or a web page that you enter your login?
zoneminder
Site Admin
Posts: 5215 Joined: Wed Jul 09, 2003 2:07 pm
Post
by zoneminder » Tue Jul 26, 2005 11:37 am
Have you tried modifying Options->Network->ZM_NETCAM_REGEXPS?
Phil
Syl
Post
by Syl » Tue Jul 26, 2005 1:15 pm
I don't have that option
I've searched everywhere, not only on the Network tab. On the Network tab I have:
ZM_OPT_REMOTE_CAMERAS
ZM_HTTP_VERSION
ZM_HTTP_UA
ZM_HTTP_TIMEOUT
I repeat: I have 1.21.0 installed (maybe this option you've told me has been implemented in a more recent version)
zoneminder
Site Admin
Post
by zoneminder » Thu Jul 28, 2005 9:12 am
Ah ok. You won't find the option then. It's not a big deal as all ti would have done was to make the behaviour the same as the version you are running anyway.
Can you do a wget -S -s <your image url> and post the first few lines, including headers?
Phil
Syl
Post
by Syl » Thu Jul 28, 2005 10:18 am
[user user]$ wget -S -s 192.168.250.59/IMAGE.JPG --http-user=XXX --http-pass=XXX
--13:13:49-- http://192.168.250.59/IMAGE.JPG
=> `IMAGE.JPG'
Connecting to 192.168.250.59:80... connected.
HTTP request sent, awaiting response...
1 HTTP/1.0 200 OK
2 Server: Web Server/1.0
3 Auther: Steven Wu
4 MIME-version: 1.0
5 Cache-Control: no-cache
6 Content-Type:image/jpeg
7 Content-Length:49038
100%[==================================================================>] 49,042 235.82K/s
13:13:51 (235.08 KB/s) - `IMAGE.JPG' saved [49,042/49,042])
IMAGE.JPG it's a blank 16x16 pixels image !
Syl
Post
by Syl » Thu Jul 28, 2005 12:52 pm
Yes ! It works !
I will soon make a HOWTO and explain what have I done to make it work. You'll here from me again !
tnx 4 da F1 !
zoneminder
Site Admin
Post
by zoneminder » Fri Jul 29, 2005 11:44 am
Good. I'm glad you got it fixed and look forward to your explanation of what you had to do!
Phil
Syl
Post
by Syl » Fri Aug 05, 2005 7:40 pm
