Some problems with 1.21.3
DarkSSJ
Post by DarkSSJ »
I have two problem with zoneminder 1.21.3:
1) I must disable ZM_OPT_USE_AUTH because when it is enabled I can't login: after entering admin/admin as user/password it comes back to the login form (and does not enter zoneminder) and this happens in loop.
2) I can only use jpeg streaming: if I set cambozola or mpeg streaming it uses jpeg. I used mpeg and cambozola streaming with older versions.
Thank you for help.
lazyleopard
Post by lazyleopard »
Which version of PHP do you have installed?
Rick Hewett
DarkSSJ
Post by DarkSSJ »
4.4.0.
lazyleopard
...then, on issue 1, see this thread (as yet un-resolved). It seems PHP 4.4.0 has changed one or two things in a significant manner, and that's broken the login handling in zm...
Rick Hewett
