Some problems with 1.21.3
Posted: Mon Jul 25, 2005 1:54 pm
I have two problem with zoneminder 1.21.3:
1) I must disable ZM_OPT_USE_AUTH because when it is enabled I can't login: after entering admin/admin as user/password it comes back to the login form (and does not enter zoneminder) and this happens in loop.
2) I can only use jpeg streaming: if I set cambozola or mpeg streaming it uses jpeg. I used mpeg and cambozola streaming with older versions.
Thank you for help.
Thank you for help.
