resolving small problems
- isladelobos
checking for gcc... gcc
checking for C compiler default output file name... a.out
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables...
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ANSI C... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking for g++... no
checking for c++... no
checking for gpp... no
checking for aCC... no
checking for CC... no
checking for cxx... no
checking for cc++... no
checking for cl... no
checking for FCC... no
checking for KCC... no
checking for RCC... no
checking for xlC_r... no
checking for xlC... no
checking whether we are using the GNU C++ compiler... no
checking whether g++ accepts -g... no
checking dependency style of g++... none
checking for a BSD-compatible install... /usr/bin/install -c
checking whether make sets $(MAKE)... (cached) yes
checking how to run the C preprocessor... gcc -E
checking for egrep... grep -E
checking for ANSI C header files... yes
checking for sys/types.h... no
checking for sys/stat.h... no
checking for stdlib.h... no
checking for string.h... no
checking for memory.h... no
checking for strings.h... no
checking for inttypes.h... no
checking for stdint.h... no
checking for unistd.h... no
checking how to run the C++ preprocessor... /lib/cpp
configure: error: C++ preprocessor "/lib/cpp" fails sanity check
See `config.log' for more details.
resolve....... install the c++
Most distro's assume that the user won't NEED
or WANT all languages supported, and they split
it up for you to choose from
---------- yum install gcc-c++ ------- in fedora
- isladelobos
anothers ""yums"" necesary
yum install gcc gcc-c++
yum mysql mysql-server mysql-devel
yum install php-mysql
yum install libjpeg-devel
yum install zlib-devel
yum install pcre-devel
yum install ffmpeg ffmpeg-devel
yum install perl-MIME-tools
yum install perl-TIME-HiRes
yum install xvidcore
yum install netpbm
yum install netpbm
- isladelobos
configure: error: zm requires libmysqlclient.a
ERROR
CONFIGURE
ln -s /usr/lib/mysql/libmysqlclient.a /usr/lib
ERROR
configure: WARNING: Now run 'perl zmconfig.pl' to create your ZoneMinder configuration
CONFIGURE
perl ./zmconfig.pl
DB user name, needs at least select, insert, update and delete privileges (alphanumeric) [] :zm
DB user password (alphanumeric) [] :hoge
Default language used by web interface (directory) [en_gb] :ja_jp
Secret used when encoding authentication information (string) [] : ZoneMinder
What width should each monitor in the montage view be (integer) [0] :0
What height should each monitor in the montage view be (integer) [0] :0
Now please create your database and database users and then run 'perl zmconfig.pl -noi' to import your configuration into the database
CREATING A MYSQL BD
/etc/rc.d/init.d/mysqld start
mysql mysql < db/zmschema.sql
mysql mysql
grant select,insert,update,delete on zm.* to zm@localhost identified by 'hoge';
quit
mysqladmin reload
--------ZMCONFIG.PL------
perl ./zmconfig.pl ZM_STRICT_VIDEO_CONFIG
----END------
make
make install
------CAMBOZOLA--------
http://www.charliemouse.com/code/cambozola/
http://www.zoneminder.com/fileadmin/dow ... bozola.jar
cp dist/cambozola.jar /var/www/html/zm
Download Java 2 Platform, Standard Edition, v 1.4.2 (J2SE)
http://java.sun.com/j2se/1.4.2/download.html
chmod 755 j2sdk-1_4_2_07-linux-i586-rpm.bin
./j2sdk-1_4_2_07-linux-i586-rpm.bin
rpm -ivh j2sdk-1_4_2_07-linux-i586.rpm
wget http://www.charliemouse.com/code/camboz ... est.tar.gz
tar xvzf cambozola-latest.tar.gz
cd cambozola-0.65
ant
cp scripts/zm /etc/rc.d/init.d/
chmod 755 /etc/rc.d/init.d/zm
chkconfig --add zm
/etc/rc.d/init.d/zm start
http://server_address/zm/
CONFIGURE
ERROR
CONFIGURE
perl ./zmconfig.pl
CREATING A MYSQL BD
mysql mysql
quit
mysqladmin reload
----END------
make
make install
cd cambozola-0.65
ant
chkconfig --add zm
Or just for Fedora Core 3
yum -c http://www.computerntelecom.com/download/zm-fc3.repo install zm
Regards,
Cordel
Regards,
Cordel
- isladelobos
uffffffff
this software is very difficult to install and to work
Now today I cannot run it
Please we we needed aa good install Documentation.
I am crying I cannot have this software
- isladelobos
you have won to me
configure: WARNING: libcrypto.a is required for authenticated streaming
checking for pcre_compile in -lpcre... yes
checking for avcodec_init in -lavcodec... yes
checking for av_new_stream in -lavformat... no
configure: WARNING: libavformat.a is required for MPEG streaming
checking for lame_init in -lmp3lame... no
configure: WARNING: libmp3lame.a may be required if ffmpeg was built with it
fedora core 3
zm-1.21.3.tar.gz
lame-3.96.1-2.1.fc3.rf.i386.rpm
ffmpeg-0.4.9-9_cvs20050517.rhfc3.at.i386.rpm
ffmpeg-devel-0.4.9-9_cvs20050517.rhfc3.at.i386.rpm
ffmpeg ----->>running----->>/usr/bin
lame-------->>running----->>/usr/lib
i don`t know resolve this warnings
fedora core 3
zm-1.21.3.tar.gz
- zoneminder
- Site Admin
- Contact:
You do not need libcrypto or libavformat to build and use ZM initially. It might be worth you just building and playing with what you've got initially and then trying to solve the missing libraries problem after.
Also perhaps use 'locate' to see if you actually have the libcrypto.a and libavformat.a libraries on your system at all.
Phil
Phil
- isladelobos
making ZoneMinder
zm_mpeg.cpp: In member function `void VideoStream::SetupCodec(int, int, int, int, int)':
zm_mpeg.cpp:88: error: 'struct AVCodecContext' no tiene un miembro llamado 'frame_rate'
zm_mpeg.cpp:89: error: 'struct AVCodecContext' no tiene un miembro llamado 'frame_rate_base'
make[2]: *** [zm_mpeg.o] Error 1
make[2]: Leaving directory `/home/isladelobos/zm-1.21.3/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/home/isladelobos/zm-1.21.3'
make: *** [all] Error 2
this error ocurred wen MAKE
- isladelobos
Have you installed ffmpeg?
yess install ffmpeg-0.4.9-9_cvs20050517.rhfc3.at.i386.rpm
and if so, did you configure it to install the share library files?
the library files install ffmpeg-devel-0.4.9-9_cvs20050517.rhfc3.at.i386.rpm
else you can run configure for zm and leave out --with-ffmpeg
[root@localhost zm-1.21.3]# ./configure --with-mysql=/usr/lib/mysql --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin --with-ffmpeg=/usr/include/ffmpeg --with-lame=/usr/lib --with-webuser=apache --with-webgroup=apache
[root@localhost zm-1.21.3]# make
make all-recursive
make[1]: Entering directory `/home/isladelobos/zm-1.21.3'
Making all in src
make[2]: Entering directory `/home/isladelobos/zm-1.21.3/src'
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/lib/mysql/include -I/usr/include/ffmpeg/include -g -O2 -MT zm_mpeg.o -MD -MP -MF ".deps/zm_mpeg.Tpo" -c -o zm_mpeg.o zm_mpeg.cpp; \
then mv -f ".deps/zm_mpeg.Tpo" ".deps/zm_mpeg.Po"; else rm -f ".deps/zm_mpeg.Tpo"; exit 1; fi
FFMPEG-DEVEL-0.4.9-9_cvs20050517
Content of RPM :
/usr/include/ffmpeg
/usr/include/ffmpeg/avcodec.h
/usr/include/ffmpeg/avformat.h
/usr/include/ffmpeg/avio.h
/usr/include/ffmpeg/common.h
/usr/include/ffmpeg/rational.h
/usr/include/ffmpeg/rtp.h
/usr/include/ffmpeg/rtsp.h
/usr/include/ffmpeg/rtspcodes.h
/usr/include/postproc
/usr/include/postproc/postprocess.h
/usr/lib/libavcodec
/usr/lib/libavcodec.a
/usr/lib/libavcodec/libavcodec.a
/usr/lib/libpostproc.so
Content of RPM :
/usr/bin/ffmpeg
/usr/bin/ffplay
/usr/bin/ffserver
/usr/lib/libavcodec-0.4.9-pre1.so
/usr/lib/libavcodec.so
/usr/lib/libavformat-0.4.9-pre1.so
/usr/lib/libavformat.so
/usr/lib/libpostproc.so.0.0.1
/usr/lib/vhook
/usr/lib/vhook/drawtext.so
/usr/lib/vhook/fish.so
/usr/lib/vhook/imlib2.so
/usr/lib/vhook/null.so
/usr/lib/vhook/ppm.so
/usr/lib/vhook/watermark.so
/usr/share/doc/ffmpeg-0.4.9
/usr/share/doc/ffmpeg-0.4.9/COPYING
/usr/share/doc/ffmpeg-0.4.9/CREDITS
/usr/share/doc/ffmpeg-0.4.9/Changelog
/usr/share/doc/ffmpeg-0.4.9/README
/usr/share/doc/ffmpeg-0.4.9/doc
/usr/share/doc/ffmpeg-0.4.9/doc/.cvsignore
/usr/share/doc/ffmpeg-0.4.9/doc/CVS
/usr/share/doc/ffmpeg-0.4.9/doc/CVS/Entries
/usr/share/doc/ffmpeg-0.4.9/doc/CVS/Repository
/usr/share/doc/ffmpeg-0.4.9/doc/CVS/Root
/usr/share/doc/ffmpeg-0.4.9/doc/TODO
/usr/share/doc/ffmpeg-0.4.9/doc/faq.texi
/usr/share/doc/ffmpeg-0.4.9/doc/ffmpeg-doc.texi
/usr/share/doc/ffmpeg-0.4.9/doc/ffmpeg_powerpc_performance_evaluation_howto.txt
/usr/share/doc/ffmpeg-0.4.9/doc/ffplay-doc.texi
/usr/share/doc/ffmpeg-0.4.9/doc/ffserver-doc.texi
/usr/share/doc/ffmpeg-0.4.9/doc/ffserver.conf
/usr/share/doc/ffmpeg-0.4.9/doc/hooks.texi
/usr/share/doc/ffmpeg-0.4.9/doc/optimization.txt
/usr/share/doc/ffmpeg-0.4.9/doc/texi2pod.pl
The problem is in the rpm install?
make all-recursive
Making all in src
Content of RPM :
/usr/include/ffmpeg
/usr/lib/libavcodec
Content of RPM :
/usr/bin/ffmpeg
/usr/bin/ffplay
/usr/bin/ffserver
/usr/lib/vhook
- isladelobos
nooooooooooooooooooooo
the errors are identical in both cases
make all-recursive
Making all in src
Regards
make all-recursive
Making all in src
- zoneminder
- Site Admin
- Contact:
I think the problem is that you are using the latest 0.4.9 cvs of ffmpeg. This changed the interface and format of some of the data structures. ZM can manage with the previous 0.4.9 version or with 0.4.8 but not the latest version currently. Your easiest solution is just to install the released versions of 0.4.8 or 0.4.9 for now until I have time and resources to figure out what has changed.
Phil
Phil
- isladelobos
yesssss
ok Phil Thank you
in this moment ZoneMinder is working in my old computer !!!
UNINSTALL
RPM -e ffmpeg-0.4.9-9_cvs20050517.rhfc3.at.i386.rpm
RPM -e ffmpeg-devel-0.4.9-9_cvs20050517.rhfc3.at.i386.rpm
AND INSTALL
RPM -i ffmpeg-0.4.9-0.20041110.3.1.fc3.rf.i386.rpm
RPM -i ffmpeg-devel-0.4.9-0.20041110.3.1.fc3.rf.i386.rpm
Requires :
SDL-devel
libogg-devel
lame-devel
/usr/bin/perl
rpmlib(CompressedFileNames) <= 3.0.4-1
freetype-devel
zlib-devel
libvorbis-devel
a52dec-devel
faac-devel
faad2-devel
xvidcore-devel
rpmlib(PayloadFilesHavePrefix) <= 4.0-1
ffmpeg = 0.4.9
imlib2-devel
........................................bla bla blaaa bla.... But this is other history
UNINSTALL
AND INSTALL
Requires :
SDL-devel
libogg-devel
lame-devel
/usr/bin/perl
freetype-devel
zlib-devel
libvorbis-devel
a52dec-devel
faac-devel
faad2-devel
xvidcore-devel
ffmpeg = 0.4.9
imlib2-devel
- isladelobos
FFMPEG
hi
today install the old fedora core 2 ffmpg and no see errors.
install this rpm in my fedora core3 and no errors
ffmpeg-0.4.8-3.1.fc2.fr.i386.rpm
ffmpeg-devel-0.4.8-3.1.fc2.fr.i386.rpm
to repair this 2 errors:
you nee install the openssl-devel
to repair this error:
