(I should say at this stage I am using the latest ZM live CD- 1.21.0)
I've used option 77 as mentioned by somebody else on here, dmesg reports:-
bttv: driver version 0.9.14 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:01:02.0, irq: 9, latency: 64, mmio: 0xdeafe000
bttv0: subsystem: 3f3f:ff3f (UNKNOWN)
bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
bttv0: gpio: en=00000000, out=00000000 in=00ffffff [init]
bttv0: using tuner=-1
bttv0: i2c: checking for TDA9875 @ 0xb0... not found
bttv0: i2c: checking for TDA7432 @ 0x8a... not found
bttv0: registered device video0
bttv0: registered device vbi0
I also bought a new camera, its a Swann "OutdoorCam", small silver affair with build in circle of IR emitters and a photo cell.
I tested this on the TV and it works ok.
When I plug it in to port 0 on the card the image is kind of split in to 3 small images horizontal, there is a sample image here:-
[/url]
I have another camera, which is some old PAL camera, this displays fine on port 1.
Oddly the image is mono too?
Ok, so I fired up 'tvtime' and I see it flick very fast from both inputs,
both images look ok, the new camera is colour, the older camera shows as mono, although I'm sure it is a colour camera?
So, I'm a little puzzled as to why the image should be repeated in three smaller images?
Any ideas most welcome!
Mike
