I'm still getting tons of alarms, with frames like these:
http://adamp.no-ip.com:10080/misc/011-capture.jpg
http://adamp.no-ip.com:10080/misc/019-capture.jpg
Could this be because my CPU is not fast enough? (I'm getting load average close to 2 with motion detection on). If so is there a way to capture on one machine and analyse on another?
Thanks!
Adam
It's still doing it.
- zoneminder
- Site Admin
- Contact:
If you have xawtv or tvtime you might want ot check and see if the camera is giving the same type of images there. If you see it in xawtv or tvtime then it could be a camera or driver issue.
Regards,
Cordel
Regards,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
- zoneminder
- Site Admin
- Contact:
