Page 1 of 1
It's still doing it.
Posted: Mon Aug 01, 2005 3:06 pm
by r6rider
I'm still getting tons of alarms, with frames like these:
http://adamp.no-ip.com:10080/misc/011-capture.jpg
http://adamp.no-ip.com:10080/misc/019-capture.jpg
Could this be because my CPU is not fast enough? (I'm getting load average close to 2 with motion detection on). If so is there a way to capture on one machine and analyse on another?
Thanks!
Adam
Posted: Mon Aug 01, 2005 4:49 pm
by zoneminder
Are these video or network cameras?
Phil
Posted: Mon Aug 01, 2005 10:32 pm
by r6rider
They are webcam captures from my creative nx pro connected via usb.
Adam
Posted: Tue Aug 02, 2005 7:18 am
by cordel
If you have xawtv or tvtime you might want ot check and see if the camera is giving the same type of images there. If you see it in xawtv or tvtime then it could be a camera or driver issue.
Regards,
Cordel
Posted: Tue Aug 02, 2005 2:55 pm
by r6rider
The images appear fine when I monitor the camera...it's only some of the captures tha appear corrupted. There's no way it could be a product of lack of processor?
Posted: Thu Aug 04, 2005 8:19 am
by zoneminder
It shouldn't be processor related. It looks more like the image is only being partially received or decoded. You probably wouldn't see the same thing in xawtv anyway as that doesn't use a grabbing. You could try dropping the max fps as an experiment and seeing is that has any effect.
Phil
