pb to connect to zm on fedora
Posted: Tue Aug 02, 2005 5:06 pm
all these 3 are present in the list
perl-DBI
perl-DBD-MySQL
php-mysql
only this one is absent, php-snmp.
but when I tryto install it, this what it say:
[root@localhost # yum install php-snmp
Setting up Install Process
Setting up Repo: ctu-updates-released
repomd.xml 100% |=========================| 951 B 00:00
Setting up Repo: ctu-Extra-RPMS
Setting up Repo: base
repomd.xml 100% |=========================| 1.1 kB 00:00
Setting up Repo: updates-released
Reading repository metadata in from local files
ctu-update: ################################################## 16/16
ctu-Extra-: ################################################## 32/32
base : ################################################## 2622/2622
updates-re: ################################################## 972/972
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Downloading header for php-snmp to pack into transaction set.
php-snmp-4.3.11-2.6.i386. 100% |=========================| 17 kB 00:00
---> Package php-snmp.i386 0:4.3.11-2.6 set to be installed
--> Running transaction check
--> Processing Dependency: php= 4.3.11-2.6 for package: php-snmp
--> Processing Dependency: libnetsnmp.so.5 for package: php-snmp
--> Restarting Dependency Resolution with new changes.
---> Downloading header for php to pack into transaction set.
php-4.3.11-2.6.i386.rpm 100% |=========================| 21 kB 00:00
---> Package php.i386 0:4.3.11-2.6 set to be updated
---> Downloading header for net-snmp-libs to pack into transaction set.
net-snmp-libs-5.2.1.2-FC3 100% |=========================| 21 kB 00:00
---> Package net-snmp-libs.i386 0:5.2.1.2-FC3.1 set to be installed
--> Processing Dependency: php= 4.3.9-3 for package: php-ldap
--> Processing Dependency: php= 4.3.9-3 for package: php-pear
--> Processing Dependency: php= 4.3.9-3 for package: php-mysql
---> Downloading header for php-ldap to pack into transaction set.
php-ldap-4.3.11-2.6.i386. 100% |=========================| 17 kB 00:00
---> Package php-ldap.i386 0:4.3.11-2.6 set to be updated
---> Downloading header for php-pear to pack into transaction set.
php-pear-4.3.11-2.6.i386. 100% |=========================| 35 kB 00:00
---> Package php-pear.i386 0:4.3.11-2.6 set to be updated
---> Downloading header for php-mysql to pack into transaction set.
php-mysql-4.3.11-2.6.i386 100% |=========================| 16 kB 00:00
---> Package php-mysql.i386 0:4.3.11-2.6 set to be updated
Dependencies Resolved
Transaction Listing:
Install: php-snmp.i386 0:4.3.11-2.6
Performing the following to resolve dependencies:
Install: net-snmp-libs.i386 0:5.2.1.2-FC3.1
Update: php.i386 0:4.3.11-2.6
Update: php-ldap.i386 0:4.3.11-2.6
Update: php-mysql.i386 0:4.3.11-2.6
Update: php-pear.i386 0:4.3.11-2.6
Is this ok [y/N]: y
Downloading Packages:
php-snmp-4.3.11-2.6.i386. 100% |=========================| 25 kB 00:00
php-4.3.11-2.6.i386.rpm 100% |=========================| 1.3 MB 00:12
net-snmp-libs-5.2.1.2-FC3 100% |=========================| 1.8 MB 00:14
php-ldap-4.3.11-2.6.i386. 100% |=========================| 32 kB 00:00
php-pear-4.3.11-2.6.i386. 100% |=========================| 332 kB 00:01
php-mysql-4.3.11-2.6.i386 100% |=========================| 33 kB 00:00
warning: rpmts_HdrFromFdno: V3 DSA signature: NOKEY, key ID 4f2a6fd2
public key not available for //var/cache/yum/updates-released/packages/php-snmp-4.3.11-2.6.i386.rpm
public key not available for //var/cache/yum/updates-released/packages/php-4.3.11-2.6.i386.rpm
public key not available for //var/cache/yum/updates-released/packages/net-snmp-libs-5.2.1.2-FC3.1.i386.rpm
public key not available for //var/cache/yum/updates-released/packages/php-ldap-4.3.11-2.6.i386.rpm
public key not available for //var/cache/yum/updates-released/packages/php-pear-4.3.11-2.6.i386.rpm
public key not available for //var/cache/yum/updates-released/packages/php-mysql-4.3.11-2.6.i386.rpm
perl-DBI
perl-DBD-MySQL
php-mysql
Is this ok [y/N]: y
