Hi Folks,
I hope someone can shed a little light on a small problem I'm having with ZM 1.21.3. Ok first off system config as follows:
P4 2.8GHz 512Mb Intel 8801 Chipset
4 Input Single Chip BT878 card (ebay special)
Ubuntu 5.10 (Hoary)
Apache2
NO - ffmpeg, lame, crypto
Ok the system has 4 PAL B/W camra's connected, each configured for Modect and everything is working like a charm!
Now for the problem, if I choose montage I get the window up with 4 video feeds however only 2 acutally show video the other two remained unloaded.
Viewing each cards monitor window induvidually works and as I say all channels seem to be recording and would appear to be able to do so all at the same time.
What I have noticed however is that I can only call up 2 monitor windows and watch the feeds. If I call up a third the window appears but is never populated.
Does anyone have any thoughts on this? Could it be a resouce issue in Apache?
My browser is Firefox 1.06 on Windows XP.
Many thanks for any replies
Regards
Simon
Montage with 4 Monitor only showing 2 feeds
This is a known issue with Firefox.
In the url type about:config
scrolll down to
browser.cache.check_doc_frequency 3
change the 3 to a 1
browser.cache.disk.enable True --> False
network.http.max-connections-per-server -> put a value of 100
network.http.max-persistent-connections-per-proxy -> 100 again
network.http.max-persistent-connections-per-server -> 100 again
This will get it working.
scrolll down to
change the 3 to a 1
