4 port capture card messing up with IRQs
Posted: Fri Aug 12, 2005 12:10 pm
i'm running livecd 1.21.3 and had no problems with a 4 port - single chip card (IVC-100G). now i changed to IVC-200(no G), which has 4 ports and 4 chips.
some infos on that card can be found here:
http://www.bttv-gallery.de/
for some reason there is something wrong with the IRQs.. and I'm really running out of ideas. it's a quite new machine, and i guess that's the problem. inside the bios there are no options on IRQs or "PNP OS installed".
almost forgot: the card is working fine on a different machine with livecd 1.21.1. on the new machine i tried 1.21.3 and 1.21.1.
thanks a lot,
acrid
thanks a lot,
acrid
dmesg | grep bttv
bttv: driver version 0.9.14 loaded
bttv: using 8 buffers with 2080k (520 pages) each for capture
bttv: Bt8xx card found (0).
bttv0: Bt878 (rev 17) at 0000:06:04.0, irq: 40, latency: 64, mmio: 0xdfb07000
bttv0: detected: IVC-200G [card=102], PCI subsystem ID is 0100:a155
bttv0: using: IVC-200 [card=102,autodetected]
bttv0: can't get IRQ 40
bttv: probe of 0000:06:04.0 failed with error -38
bttv0: Bt878 (rev 17) at 0000:06:05.0, irq: 41, latency: 64, mmio: 0xdfb05000
bttv0: detected: IVC-200G [card=102], PCI subsystem ID is 0101:a155
bttv0: can't get IRQ 41
bttv: probe of 0000:06:05.0 failed with error -38
bttv0: Bt878 (rev 17) at 0000:06:06.0, irq: 42, latency: 64, mmio: 0xdfb03000
bttv0: detected: IVC-200G [card=102], PCI subsystem ID is 0102:a155
bttv0: can't get IRQ 42
bttv: probe of 0000:06:06.0 failed with error -38
bttv0: Bt878 (rev 17) at 0000:06:07.0, irq: 43, latency: 64, mmio: 0xdfb01000
bttv0: detected: IVC-200G [card=102], PCI subsystem ID is 0103:a155
bttv0: can't get IRQ 43
bttv: probe of 0000:06:07.0 failed with error -38
lspci -v
06:04.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Ncipher Corp Ltd: Unknown device a155
Flags: bus master, medium devsel, latency 64, IRQ 40
Memory at dfb07000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
06:04.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at dfb06000 (32-bit, prefetchable) [size=4K]
06:05.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Unknown device 0101:a155
Flags: bus master, medium devsel, latency 64, IRQ 41
Memory at dfb05000 (32-bit, prefetchable) [size=4K]
06:05.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at dfb04000 (32-bit, prefetchable) [size=4K]
06:06.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Unknown device 0102:a155
Flags: bus master, medium devsel, latency 64, IRQ 42
Memory at dfb03000 (32-bit, prefetchable) [size=4K]
06:06.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at dfb02000 (32-bit, prefetchable) [size=4K]
06:07.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: Unknown device 0103:a155
Flags: bus master, medium devsel, latency 64, IRQ 43
Memory at dfb01000 (32-bit, prefetchable) [size=4K]
06:07.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at dfb00000 (32-bit, prefetchable) [size=4K]
cat /proc/interrupts
CPU0
0: 1709890 IO-APIC-edge timer
1: 1271 IO-APIC-edge i8042
2: 0 XT-PIC cascade
8: 0 IO-APIC-edge rtc
14: 49 IO-APIC-edge ide0
16: 24032 IO-APIC-level eth0
20: 11405 IO-APIC-level libata
NMI: 0
LOC: 1709931
ERR: 0
MIS: 0
