pb: zm install on debian
MK
Post by MK »
hello!!
I have a pb with zm install on debian.
I have installed it first time without pb following the instructions of matrix, but now when I 'apt-get install zm'
Les paquets suivants contiennent des dépendances non satisfaites :
zm: Dépend: libgcc1 (>= 1:4.0.0-9) mais 1:3.4.3-13 devra être installé
E: Paquets défectueux
traduction:
The following packages contain unsatisfied dependences:
Zm: depends: libgcc1 (> = 1:4.0.0-9) but 1:3.4.3-13 must be installed E: defective Packages
can you help me, What may I do to fix that, or to install the correct libgcc recquiered??
thx
mk
cordel
Post by cordel »
You need to install install libgcc > = 1:4.0.0-9 as it says above.
Also may I suggest not to double post please? If some one can answer your question they will. It's kinda rude to double post.
regards,
Cordel
MK
Post by MK »
sorry, i will remember!
thanx.
I try to do it, but can't install with apt-get...
I will try again!
thx
mk
maximum
Post by maximum »
MK wrote:sorry, i will remember!
thanx.
I will try again!
thx
if you still need zm for Sarge, please write me. I'll send it by mail.
ciao
MaX
