Minimum record time?
blaxer
Post by blaxer »
Is there such a thing as a minimum event record time? I have tried adjusting the buffers but it doesn't seem to do it. On some cameras I would like ZM to record a few seconds before and quite a few after the alarm event. TIA!!!
jameswilson
Post by jameswilson »
you are rin the right area how many seconds pre alarm and post alarm do you want and at what framerate you capturing?
James
blaxer
Post by blaxer »
on most of the cameras I have the maximum fps set to 10 or 15, I would like something like 5-8 seconds before and around 30 seconds after. When I increase the buffers to what "should" be that ammount of frames I never get any events.
cordel
Post by cordel »
Increase to what you want and restart. You may have to adjust your shared memory and thats why you are not getting events. If you check the zmdc.log I bet you'll find shmget errors. See the FAQ.
Regards,
Cordel
